Has coil replacement fixed anyone's misfire/stutter?
Old 02-05-2014, 11:01 PM
Yokiebear's Avatar
Originally Posted by Christina Diaz
Any luck with this? I read this in a later post as well!
I can confirm that I have had no problem with my 2008 Fit misfiring, studdering going up a hill or engine dying at a stop light after they replaced the 4 coil packs. I also asked Honda about replacing the plugs and adjusting the valves but they said that it is not necessary until ~150K or something like that.
I'm still dealing with what I perceive as bad gas mileage but I really haven't done anything to diagnose that issue yet. A few of the guys had some ideas a few posts back so I might bring it into Honda again to have them look at it during the next oil change.
The 4 coil packs cost me about $630 to get it back to reliability. I was almost at the point of selling the beast and getting a new car.
  #182
Old 02-06-2014, 12:51 AM
Marrk's Avatar
Glad the coil packs worked for you.
Bad gas milage might be cured by a valve adjustment.
  #183
Old 03-05-2014, 07:05 AM
stevearnimbrown's Avatar
2004 jazz misfiring on acceleration
after 250,000 kms of care free motoring (except for a few rear wheel bearings that Honda eventually admitted liability) my Jazz's engine momentarily cut out on gentle uphill acceleration in 4th or 5th gear. Odd occasions initially, but got steadily worse. Googling possible causes came up with: petrol filter, Air filter, VTEC gearbox, coil packs x 8 @ $200 each.
I changed all 8 plugs NGK 1mm gap (need a short piece of hose pipe that fits over plug end to withdraw plugs from deep recess after unscrewing) Note: also helps to remove old plug before trying to screw in new one) Cleaned and sprayed coil packs with none conducting anti corrosive spray.
Sweet as a nut now.
Regards,
Steve
  #184
Old 03-05-2014, 02:22 PM
einstein77's Avatar
How'd you do it?
Originally Posted by stevearnimbrown
Cleaned and sprayed coil packs with non conducting anti corrosive spray.
Sweet as a nut now.
Regards,
Steve
What do you mean you sprayed the coil packs? Did you spray internal and external of packs?
  #185
Old 03-05-2014, 02:36 PM
Marrk's Avatar
I had the same question.
  #186
Old 03-07-2014, 07:27 AM
Jazz / Fit misfire on acceleration
Just cleaned external and sprayed inside open end of coil packs. The type of misfire / stuttering on acceleration that I experienced made me think that
The fault would more likely to be caused by a momentary fuel starvation or electronic ignition misfire because all 4 cylinders misfired together. I reasoned that the failure of one or 2 coil packs would cause only one cylinder to misfire.
But in my case it was obviously either the plugs at fault or dirty coil packs.
Regards,
Steve
  #187
Old 03-11-2014, 08:43 PM
ldramjet's Avatar
After working with this misfiring issue for three years, it finally got so bad I could not drive my 2007 Fit down the highway. Fortunately, 15,000 miles previously, the issue was identified by the dealer who was able to play musical chairs with the coils and identify which was bad. It was under warranty at the time. This time the issue was much worse and the mechanic could not get the problem to recreate, which shocked me, even though the codes showed there were issues with the valves misfiring. I left my car with him until the weather conditions were right and the problem magically reappeared. Apparently cold or extremely humid weather caused the car to misfire and, of course, it was sunny and warm when I got it to the mechanic! Fortunately, the mechanic was able to identify three bad coils - all that had not been replaced by the dealer previously. It has been running great and problem free for the first time since shortly after I bought it. So yes, replacing ALL of the coils fixed my issue along with my horrible gas mileage!!!
  #188
Old 03-12-2014, 09:00 AM
Edison Carasio's Avatar
At about 125,000 miles I started throwing a misfire code and missing REALLY bad. It was almost unbearable to drive. I pulled the coils, found one that was nasty burnt and replaced it but no luck.
I saw when this starts, just replace all 4 along withthe plugs (I had just replaced my plugs at 110,000 miles so it sucked spending money on them again, but I figured may as well if one of them was fubar'd from the bad coils).
It hasn't done it since. But it does have a rough idle when cold so I think a valve lash adjustment is in order to put her back to like new.
  #189
Old 03-12-2014, 01:53 PM
einstein77's Avatar
Hopefully, coil replacement is the answer for most, here.
  #190
Old 03-12-2014, 01:55 PM
einstein77's Avatar
Keep us posted as you progress in mileage. Hopefully, this will be the fix for you.
  #191
Old 03-12-2014, 06:09 PM
thefit09's Avatar
My GE had a coded misfire on all 4 cylinders after a rough start, but there wasn't any hesitation during driving. I cleared the codes and it hasn't happened since. Been driving about a week with no issues/or codes. I'm at 69k miles. I noticed that the GD's and GE's use the same coil packs. Is it possible that I'm getting the same issues as several of you other GD owners.
  #192
Old 03-13-2014, 11:57 AM
einstein77's Avatar
Are you sure?
Are you sure about that? I have a GD and GE and every time I've looked up coil packs for these cars they have different part numbers.
  #193
Old 03-13-2014, 12:44 PM
thefit09's Avatar
I think you're right after looking into it more. 09 - 11 Fits as well as '11 CRZ it looks like use the same ones.
  #194
Old 03-15-2014, 02:34 PM
Fit_Dr's Avatar
I replaced coil packs somewhere around 150K after developing a stutter and it cleared right up. Bought them from Rock Auto...Hitachi I think.
  #195
Old 07-30-2014, 01:13 PM
quad3datwork's Avatar
Short story:
Replaced all ignition coils, seems, to fix all the problems. Stutter, misfire, RPM variations, engine shut offs.
Long story:
I've had this problem for 3-4 years now? Last year cylinder #2 finally gave out and car went into limp mode. I paid $270 to a shop to get #2 ignition coil replaced. Had no choice, Fit is my only means of transportation.
About two weeks ago, the engine started to get REALLY rough. Like, stuttering low and high RPMs. Engine shut off 3 times while stopped. Sometimes loses good amount of power when press gas padel. So I ordered 3 new ignition coils and OBDLink MX from
Amazon Amazon
(Fortunately the ones I ordered from Amazon is the same coil the shop replaced last year. So they all match.)
Replaced cylinder #1, #3, and #4 last night. So far so good!
You can see the pictures below. Cylinder #3 had really bad discoloration. So I believe it was on its last leg.
My car is 2007 Honda Fit with almost 140K miles now.
  #196
Old 07-30-2014, 02:54 PM
SloEg701's Avatar
My car does the same when I'm stopped and everytime when I go over a bridge it deaccelartion
  #197
Old 07-30-2014, 06:24 PM
ikutoisahobo's Avatar
What's up with cylinder number 3 anyways? Mine had a nasty coil on the cylinder as well, all other coils looked way better appearance wise. And the spark plug was loose on that cylinder, kinda weird.
  #198
Old 09-28-2014, 03:34 PM
Hamdude's Avatar
Yes, Honda should have taken care of this for free with my car, as I've had problems with this since less than 30K miles. Over 50K more before they finally "figured" it out.
  #199
Old 09-29-2014, 09:53 AM
doctor J's Avatar
I will pull mine coils next month to make sure it does not look like #3 cylinder coil on the picture.
While working on customer's 2001 Tribute V-6 3 spark plugs were tightened correctly, 2 were too tight and one was very loose (however coil looked OK)
Back in 2002 the 91 Camry V-6 had burned spark plug wire boot and spark plug not tightened (the gasket was not compressed)
This is when I am doing plugs on engines requiring intake plenum removal or extended service interval plugs I am always using small torque wrench to be sure!!
  #200
Old 10-02-2014, 07:59 AM
lakia5524's Avatar
holly crap was the spark plug for 3 fouled out?
Quick Reply: Has coil replacement fixed anyone's misfire/stutter?
