Fumoto valve available for Fit?
Fumoto valve available for Fit? YES
UPDATE 5/5/06:
Here is what the company emailed me about working with the Fit. I like the form letter feel
The official Fumoto site is: www.fumotovalve.com, but I ordered the Fumoto Valve for our Forester from Lubrication Specialists for cheaper.
Thank you for your inquiry of May 3.
Or part#F106(size 14mm-1.5) is a suitable application for
2007 Honda Fit w/1.5L engine.
We appreciate your interest in Engine Oil Drain Valve.
Best regards,
YM International Company
On-line Distributor of Fumoto Oil Drain Valve www.fumotovalve.com
Best regards,
I would assume that it's the
Honda
All models w/ 4cyl. engine from 1984 & on
F-106
I doubt that Honda changed the thread for the FiT since it also uses the same oil filter that is on every Honda since 1984.
But let us know if that works, I am interested in one of these. Pretty cool little item.
Honda
F-106
Originally Posted by sillypuddy
i would be always scared that the "safety" valve would open and i am SOL
-joe
-joe
Originally Posted by JDMGD3
Ya that would be my concern also. People must really be getting lazy if they cant even loosen one bolt underneath the car that they need an invention like this to help them.
I had the oil fall out of my Jetta once. Oil light comes on, pull over, call tow truck, get shattered oil pan replaced, add oil, keep driving...
The key of course is to stop driving when the oil has left the building.
Originally Posted by drknife
In the manual you will see that there is a crushable washer that needs to be replaced every time the oil plug is removed. This would make it possible and cheaper for people to change their oil at home without buying a box of special honda washers.
That washer is 75 cents at the most, you shouldnt be driving a $15k car if you cant even afford 75 cents every 3 months or 3K miles.
-joe
I like how much faster and cleaner it is using a fumoto valve. It directs the oil in a small, controlled stream. That, and it's one less tool to get out.
These valves are pretty foolproof, I wouldn't worry about them leaking. Tons of folks on the Subaru Forester forums have them and haven't had any issues.
Worth every penny to me!
Still haven't heard from Fumoto, but bschurma, you're probably right about which valve would fit.
I've got to chime in here (donning flame retardant clothing, too!)
I bought my first Honda in February, 1978. I've had one ever since. I've always changed my own oil.
I've NEVER replaced the crush washer. I've NEVER had a leak, drip, or whatever.
I just don't get it. Does someone's brother work for a place that makes aluminum washers, or something?? I've never understood this!!!
Also, get a 17mm box-end wrench to remove the oil drain plug.
YMMV ---
YMMV ---
LOL, I forgot about this thread. I need to order one soon, since I think we're down to about 30% oil life and I want to change it around 5 to 10% (or 5000 miles).
Wyy, good point about the box-end wrench, for those that wouldn't want to get a Fumoto valve.
Originally Posted by dougiepants
This is kind of cool.. but I really see no need for it...
I have something similar on my Tiburon. It has a threaded receiver on which you screw the drain connection (which has a soft rubber tube) that opens the valve when it's screwed on all the way. There is also a cap to screw on to protect the threads.
Since I change my own oil, it's worth it to have. I can't remember how much it was, but I think it was around $15. I'll be putting something similar on the Fit, since I will be doing most of my own maintenance.
YMMV ---
YMMV ---
Just updated the post. When I ordered way back for our other car, I got it from Lubrication Specialists for cheaper.
-joe
-joe
for the naysayers: don't buy it. it doesn't do your dishes and it won't add a mysterious extra optical inch to the dangle. it's just a valve.
for those on the fence: are you dirt poor? don't buy it. do you have 25 to spare? do you often find yourself not really worrying about money? do you just have a tendency to spend way too much? then buy it. if you never change your own oil this will be useless, but that kind of person probably has not clicked this thread.
for those who want it but are skittish: you won't lose all your oil. you don't really need the nipple'd one, and you really don't want it if your bolt hangs low like mine (with my drop it's less than 6" off the ground). if you're really scared, get an aluminum undertray. using this in conjunction with my canton mecca oil filter (cartridge setup) made oil changes incredibly easy and shaved 10 minutes off of them. that's a lot when you go through nearly 10 minutes jacking up the car because you have to jack up both sides in the front....my car lifts 2 extra corners because it is too stiff.
for those who will always believe it's just too much money for a valve: click back?
um... what? take a pic? i don't (yet?) own a fit so i have no idea what the spot looks like, but i'd assume the hole points down. the fumoto valve just puts a hole in the top of the bolt with a valve to control flow.
