recommend a torque wrench for tire rotations
Being as i calibrate torque wrenches and other test equipment i have come across most big names out there. Craftsman torque wrenches are not worth the money. If you have a bit extra cash to spend go with Snap On. I rarely have to adjust them or replace the pall. They are solid wrenches. Also i would stay far far away form Armstrong. They arent that popular with normal mechanics but a lot of businesses and people we support use them and they are garbage. Just my experience and advice, hope it helps.
Also if you want something that works well but is a "tad" less user friendly go with a dial or deflecting beam wrench. They are just as accurate(in the case of dial usually more accurate) than snap action and they don't break or come out of adjustment as much as the snap actions. Also a lot cheaper for the most part unless you go for the +/-2% snap on dials which is just not needed for what you will be doing.
Ah i could have been more specific, honestly never come across a craftsman deflecting beam so my mistake. Honestly any beam wrench should never break or give severely inaccurate readings unless you a) beat the hell out of it or b) the beam becomes bent. But i agree with you Fa1, had i known they had a beam wrench i would have said something about it, but for $30 and knowing your lugs are atleast pretty damn close to what they are suppose to..cant beat the price.
wooo hoooo got me some tools
Went to Harbor Freight and got a $20 dial 1/2" torque wrench (20-150lbs)... glad someone recommended that desired torque should not be at the end of the useful range as I almost did that.
Got some deep socket nut drivers and did a few tests... I am excited to be able to do tire rotations myself. Now I will have little need to go to the dealership
I will probably use the money I save on premium oil to eek out some more performance. Plus I'll change the cabin and engine filters more often as I see fit (no pun intended)
I feel so empowered
I feel so empowered
Great Evil
09-15-2015 12:49 AM
