What is the cold cranking amps for 07 stock battery?
Old 12-09-2008 | 04:56 AM
jchcmax's Avatar
Would someone please go look at their stock 2007 battery and tell me the cold cranking amps, or "CCA". My old stock battery had the blue/red circle status indicator. This type of battery has the "CCA" printed on it. I think it was 425 but I'm not sure...It should be listed on top of the battery near the negative terminal. I need to know exactly what it is. I'm looking for the Braille replacement. I don't need to know what Braille will fit or what you have , just need to know the stock battery "CCA". The battery that came with the car brand new took a dump. The dealer replaced it for free because it pooped within 3 years. The battery they put in does not have any markings on it. I intend to replace this battery with a Braille battery when it's time..thanx. BTW, hi from SoCal to the freaks out there!!
Old 12-09-2008 | 08:35 AM
NIGHTHAWKSI's Avatar
i just replaced a battery the other day...and i think it was 425. however, i also used to have the oddessy pc680 battery in my car and it worked perfectly
the specs of this battery are:
CCA - 220
680 cranking amps for 5 seconds
595 cranking amps for 10 seconds
525 cranking amps for 20 seconds
i know this isnt the info your looking for, but it just goes to show that you can go much lower cca than OEM and it will still work.
and i highly recommend the passwordjdm battery and relocator kit. it fits the car perfect, requires no extending of any wiring, and frees up ALOT of space in the motor. very clean install that can be done in about 20 minutes with the right tools.
Old 12-09-2008 | 10:24 AM
dewthedew's Avatar
pics of the password jdm kit installed? will it fit a braille battery?
Old 12-17-2008 | 10:10 PM
DOHCtor's Avatar
on my battery it says 320CCA... it should be 4xx CA at least.... Car is kinda hard to start in the -20 something we get here...
Marko!!
Old 12-18-2008 | 06:01 PM
jchcmax's Avatar
Marko!!
Thanks for taking the time to check. You rock!
Old 12-18-2008 | 08:14 PM
DOHCtor's Avatar
No problem!! That wasn't a big deal anyway as the stupid black plastic cover is off anyway!!
Marko!!
Old 01-05-2014 | 10:47 AM
willmax11's Avatar
Marko!!
Don't forget that rating is normally @ 32F. A battery loses a lot of power below-20.
Old 01-05-2014 | 02:54 PM
n9cv's Avatar
I do not know where you are in Manitoba but about 1/2 hour ago I was checking temps around North Dakota. I clicked on Brandon and see it is currently -24 F in the middle of the day. I make it to the Peace Garden and Brandon almost every year IN JULY.
Jensen Healy
12-06-2019 02:54 PM
Zero2Hero
02-09-2019 10:03 PM
littleblackcar
04-22-2016 12:12 PM
HKDM808
10-18-2012 06:24 PM
piclistguy@yahoo.com
05-04-2005 11:16 AM
Quick Reply: What is the cold cranking amps for 07 stock battery?
