S2000 fit?
Old 09-27-2008 | 07:29 PM
matrix02's Avatar
S2000 fit?
I have (4) S2000 oil filters (15400-PCX-004) left over after I traded it in. I read a forum in here that this filter will work in the Fit. I just wanted to confirm this. Also, is there any problems like leakage or anything.
Old 09-27-2008 | 08:37 PM
dank24's Avatar
I doubt anyone has tried to fit a different filter from a different model on their Fit. How about cross matching part numbers and see if they are the same? Or just trying it out yourself?
Old 09-27-2008 | 08:49 PM
petwhookie's Avatar
I went to the dealer and they said every honda oil filters were the same besides the s2k and oddesy (not 100% sure about this one).
Old 09-27-2008 | 10:07 PM
matrix02's Avatar
this is the link where i found that the s2000 oil filter might work in the Fit.
https://www.fitfreak.net/forums/fit-...t=s2000+filter
just wanting to make sure it will work on the Fit before I try it. Otherwise, I will just put it on ebay.
Old 10-03-2008 | 10:53 AM
ArdentAzn's Avatar
As far as fitment, the S2000 filter WILL fit... It is slightly bigger than the ones for 'regular Hondas'... However, I have heard that due to the difference in engine demands, our fits might not have the necessary oil pressure dor the S2000 filters... I don't know how this would affect it, but this is the conclusion I got after hours of research... Hopefully someone can enlighten/explain this???
Old 10-03-2008 | 07:05 PM
SYMBIOTIX's Avatar
I used to run s2000 filters on my EP3 all the time. They are a higher quality if you get the right part number - specifically you want the filter made in Hong Kong by Toyo Roki. I think there is another one made for the s2000 by honeywell/fram which is garbage.
Good luck
Old 10-05-2008 | 08:41 PM
i usually cross reference via the mobil site on filters. ends up my legacy and
G35C both use the M110, so i can use my nissan filter on the legacy if i wanted
and viseversa. lol (not that i would, but they fit).
Old 10-11-2008 | 04:12 AM
HONDAMATIC's Avatar
the only honda ones that are the different ones are the s2000, nsx, legend, 96-98 3.2TL.. I put honda filters on my gfs g20 and other nissans...
Old 10-24-2008 | 05:49 PM
Tofuman's Avatar
I know the S2000 filter fits on K20's. I remember reading about it back when I had an EP3. The Fit and the K20 engines use the same filter, so it should fit just fine, but i don't know about the oil pressure issue that has been brought up.
Old 10-28-2008 | 07:47 PM
bigg_kidd's Avatar
i am still using the oil filters on my FIT that was on my 05 integra type S, and they fit just fine. that saved me hella money
BenjaminFit
03-23-2011 12:49 PM
Mclaren_Honda
11-19-2009 06:46 PM
Lek
07-04-2009 03:34 AM
kinosh
09-27-2008 10:10 PM
ricohman
09-23-2008 07:14 PM
Quick Reply: S2000 fit?
