Axels are taking a S**T
Axles are taking a S**T
I now have 65k miles and I have started to notice some odd play in the front suspension under load in turns at high speed. I am not sure if this has to do with the axles yet, but as I inspected the front lower suspension I noticed a ring of axle grease spun all around in the fender well. Its not just on one side but both.
I have done some racing with it at a local SCCA event, but I was wondering if anyone else has noticed this. I have lowering springs(installing T1R Bmaxs when I saw this) and RCAs.
The drivers side seems to have a hole in the middle of boot thats against the tranny thats loosing the grease on that side and the pass. side, it seems like its coming off the end boot right near the hub where the band clamp holds it on. It actually looks like the band clamp is tearing into the side of the boot.
I am also wondering if there is a putty, sealent, or silicone that could seal it enough before they dry out completly or is it too late.
Does anyone even make new ones?
they dont just slip on, you need to remove the end of the axle from the spindle, knock off the kunckle (w/o damaging it), and repack the joint, before reassembly
