Rust & Paint
Rust & Paint
Howdy,
My Fit became scratched a couple of months ago and I tried to apply touch up paint to parts of it. There were some parts though that got scratched down to the metal and began rusting. I just went to a repair shop and they gave me a quote for >$800!
I'm thinking of getting rid of the rust and doing the paint job myself. Can anyone tell me if the instructions on this site is good to follow: Video:**How to Fix a Scratch on a Car | eHow.com? Also, is the Fit's paint enameled?
Thanks for any replies!
Its not enamel (edit: you know what?...I recall hondas in the mid 90's to have acrylic enamel, edit:call your dealer...cuz I cant shake that old accord being enamel...but I cant imagine the fit being enamel....)
The directions are ok...use like a degreaser that gets rid of wax...
600 grit is good (edit: for starters I prefer 800...and higher if possible...but my buddies use 600)
use a bigger mask than what they use in the video
you can use primer too (dont have to necessarily)
I would make the mask slight irregular shaped and would polish it after a week, to blend it in better.
2-4 light-ish coats every 5-25 minutes depending on your weather/temp
clear coat it if you want but wait longer after the other coats and even then I would only do it if you dig the coverage and are ok with the finish so far...
hope that helps...
Ohh crap! dont forget to do a test spray a few times to get the proper feel for distance and for even coverage and proper application
hope that helps...
Last edited by Snap Fit; 01-06-2008 at 12:08 AM. Reason: Because the "edit" button is the new " COOL " !!!!!
If you notice at the end of that video, the painted area is lower than the surrounding area.
Another way to make the repair almost invisible is to use a brush. First sand the rusted metal ONLY. Then paint some primer into the gouge.
After that apply several layers of paint using a touch-up brush from the dealer. The object is to get it higher than the surrounding paint.
After that you have two choices to achieve a level surface:
1. LANGKA paint blob leveler
2. The EASTWOOD Final Finish System kit
Both will make the repair practically invisible. Search the Web for complete instructions and videos...
