MT oil change-over to RED LINE oil
Red Line (from Martinez, CA) is a product line aimed mainly at the racing market, where lubricants are changed much more frequently than regular maintenance schedules from auto makers owner's manuals. The main shortcoming in it being used in a daily driver is, it gets dirty faster than other synthetic brands such as Amsoil. Financial result- Amsoil costs less due to longer service life. Most synthetic brands give better wear resistance than any mineral oil.
should point out that I spend 6.5 hours one way to work at 80MPH. once to work and once back home per week,,,85% of it is freeway, the other 15 % is mountain driving,,,I knew I could get some varied views on the subject,,,thanks
Supposedly the Honda MTF is a good blend...balanced between the needs of the gears (slippery = GOOD) and the synchonizers (slippery = NOT SO GOOD).
I changed out the MTF in my CR-V after 15K miles with the NEW Honda MTF stuff. Also added a couple ounces of 5W-20 Synthetic motor oil (which is noticeably MORE slippery than the Honda MTF). Darn if the shifting isn't easier now.
No shifting or synchonizer problems after 10K miles.
![Cool](https://www.fitfreak.net/forums/images/smilies/cool.gif)
![Wink](https://www.fitfreak.net/forums/images/smilies/wink.gif)
I don't understand how in a closed system the type of oil can make the difference in how clean or dirty the oil gets. There should be the same amount of dirt/grime with one oil verses another (the dirt coming from the tranny , not the type oil) , and seeing how there is no filter to clean it how can brand name make a difference?
![Confused](https://www.fitfreak.net/forums/images/smilies/confused.gif)
This statement is true for motor oils. A RACING oil will have less detergents (for example) in its additive package than a STREET oil because it is assumed it will be drained and replaced every race or two.
That said, a lubricant designed for a transmission will have different additives than for a motor or differential. The uses are different.
I still stand by my earlier post, the Honda MTF formula is Good Stuff and should be all you would need in a street car.
Honda is famous for using Engineered Fluids in it's mechanisms. Not just stuff they buy off-the-shelf.
Odie
11-23-2019 07:31 PM
GeneralLee86
08-14-2015 09:28 AM
