The stock Fit on the track
I love my MR Fit - but I have a question. The engine is stock - no air intake or anything else. It is my daily driver - and I am super protective
of it. Anyway, another group of WV car people that I belong to are having a meet and they are going to have use of a quarter mile track. There is an event plan around the meet which has tuned out police cars coming in from out of state to race against other drivers. It is all for fun and to encourage kids to race on the track and not on the street. Would it hurt the Fit to do this? I know that I have once or twice started at the stop light and hit it hard until I got up to the speed limit but I just would not want to hurt the car. It would not be worth it to me. Most likely will be the only Fit there and I have to say my plan was to go and just enjoy the meet and watch the races. The guys are after me to race the Fit and they are having a photographer there to take pictures. I know the Fit is not going to beat anything out there and it is just for fun but I just worry about putting it to the test. My answer is no just go watch but I would like your opinions as well.
What do you all think?
Cat :x
Cat :x
I would change my oil the day before just in case. Also, I'd put high octane in the gas tank cuz it can't really hurt to spend extra dollars to be on the safe side. Most cars that are well built should be able to withstand a beating when they're well maintained. Good luck on the track!
Your car has a redline for a reason. If there was danger in high-revving your engine, dropping the clutch, burning out, and pushing the car to its limits, YOU WOULDN'T BE ABLE TO DO IT. Cars are made to do these things (occasionally, of course)!. If (god forbid) you damaged your car, its because you did something wrong, not because the car cant handle it. GO AND HAVE FUN!
My MR Fit Sport is an AT so I don't have to worry about the clutch. I feel really good driving the Fit and with its great handling and steering don't see any problem there. Thanks for your input - I am still at 30% with my oil so I estimate that I will be ready for the first oil change sometime in March - God I've own the car for a year in May and still haven't had the first oil change yet ! Of course I am only a few miles from work and back so that has the mileage low and I never take any long trips. I have about 4800 miles on it so far.
Cat :x
Cat :x
hey cat,
I'd have to disagree with that comment about using high octane gas in your car. use the regular octane.
As for whether or not you should race your car, it's totally up to you. It would definitely be a fun experience, and your first time on the track you might get butterflies in your stomach and a rush of adrenaline, it's really something you should experience if you're willing to. as for the safety of your car; yes you definitely are running a higher risk of damaging something when you race your car, but like you said, you take good care of your car. so letting loose on it once in a while will not be hurting it as much as some people who don't take care of their cars or thrash on it daily. in summary, you do have a higher risk of hurting the car, but it is so low that it can be practically guaranteed that nothing bad will come out of a day at the track.
If you decide to do it, have fun and don't worry! and make sure you know the rules and the procedure before you race, some tracks aren't very good at explaining things to the drivers, but you will be with friends so i'm sure they'll help you out if you have any questions.
you should be perfectly fine....
Actually since you have the sport AT you can just leave it in "S" mode and floor it! It will automatically shift for you at a higher RPM than regular D mode. From what I have heard. I know TOOL knows more about it than I do though (I have an MT)
-just make sure you do a thorough inspection of your car before hand...and enjoy!
uhhh dont crash! (that would be an easy way of damaging your ride )
you will probably really enjoy it too, and best part is you will end up knowing more about your car in the process (which is always usefull, with regards to limits and sounds and such)
DOOO IT...DOOO IT....DOOO IT....HAAHAA
If you choose to do it though you might be like this guy > < and will be anxious to do again...heehee
Snap Fit... love the smiley guys! lol totaly how i am! and Fit on a track should be fine... i am no gentle on my car on the street and the car is fine, just go and have fun! i wish i had the opportunity to get on a track!
Per everyone above, go for it! The car will be perfectly fine and you will have a great time. I took mine out autox'ing last summer and had a blast, and plan to again this season as well as a track day or two if money permits. It was an awesome experience and the car was completely fine. You will be amazed at what the little guy can do, trust me.
Posts in the NUUDE
Dont change anything. Dont change the oil (unless it needs it) and DO NOT run higher octain gas. It wont do anything.
The day before and on the way to the track beat on the car a little. While cruising mash the gas and make it down shift. Also take the car to redline a few times from stop lights. It puts the ECU into a higher performance mode. It wont be stuck in econo mode
When you get to the track avoid the water box. Its a dip that water runs threw way before the stagging tree. Its for cars with slicks/drag radials. Gets them slippery to prevent breaking axles and rear ends when doing burnouts.
AVOID the box. Drive around it and stage.
When youre stagged and ready to go. Hold the brake firmly and mash the gas at the same time. This will bring the RPMs up without the car moving. Yes its going to sound a little harsh on the car but a few times wont hurt the trans. On the last yellow light release the brake while still on the gas.
Should give some decent 60foots. And of course, S mode it.
Moved to Fit Racing.
The Fit is NOT a track car stock. Especially not the AT. BUT you can still have fun and it is a Honda and they love to rev. So yeah i would go do it! If your going to do it regulary i recommend the KW supercharger.
Tyler
Tyler
Tyler
Hey Cat,
This being a 1/4 mile, we are talking dragstrip, right? I know we are, but I think some others are picturing a different type of racing.
Regardless, I must agree with the others. Use S mode, don't paddle-shift, have fun.
IMPORTANT: Don't shift in S mode while staging. You will bounce off the rev-limiter when first gear winds out. Instead, get staged without ever touching a paddle. Or get staged in D mode, and then shift to S when you're stopped, waiting to race.
My AT Fit will not beat a school bus off the line, but it should be fun anyway. Wish I was in WV, I'd like to have a chance to race 2 stock AT Fits!
Good luck!
PS: You need to drive more. It isn't good for your car to just make short hops; that's why it's recommended that you change your oil every 6 months if you haven't put many miles on the car. Oil gets moisture / condensation that will only begin to evaporate when the engine is up to normal temp. Plus, it would make me feel better, since my car arrived last March too, and it has over 30,000 miles now.
Good luck!
Hey Cat,
Good luck!
Good luck!
Cat :x
Posts in the NUUDE
Good luck!
Good luck!
Hey lady! Wanna race? Wish I lived closer to you, maybe I'd join you (or race you......and WIN!!!! (Are you inspired yet?) We could start the Women's Geriatric Fit Racing Club!
Or better yet, the Middle Aged Fit Racers Without Dicks!!
(Actually, that's kind of sad) Sorry, gotta do something to keep my mind sharp.
Do it girlfriend!! Then you can teach me. 'Grand Prix' was one of my favorite movies as a kid (about 10 years old). My dad took me to it at the Hollywood Theater in Portland Oregon where it was a partial wrap-around screen. It was awesome!
That's right
That's for sure. I do it occasionally myself, when I need to beat someone else away from a traffic light. It'd be nice to have more torque, huh?
