Recommendations for clutch replacement
Okay Fit Freaks,
After 162,000 miles my clutch is going away quickly and I need to have it replaced this week. Any suggestions in OC of people or shops that are quick and reasonable? Lake Forest Transmission replaced the main bearing in the tranny 4 years ago ($40 part and $800 in labor...) at that time they said my clutch wasn't even 50% worn, so I left it. They are supposed to give me a quote Monday. I've used Mark at MD Automotive in Westminster (formerly Jackson Racing) to swap my motor, but they're closed today, so I'll check with him on Monday. Any other suggestions? Just going stock since it lasted so long.
I'd use AAMCO way before most dealers,,, There is a chain called clutch doctors, I've used them twice.. Came out well.
The dealer is not going to do anything the trans shops dont do and you get less of a warranty .
The Proper Fit
08-09-2023 11:46 PM
jits14
11-20-2007 04:52 AM
