tire size recommendations?
Old 05-02-2011 | 02:49 PM
Fitcious's Avatar
question guys:
need new tires on my stock wheels on a 2009 fit sport.
the only reasonable priced for stock dunlops i got quoted was $450 OTD.
I am thinking about going up in size: if i do, what size?
195/55/16
195/50/16
205/45/16
i am on stock height. i do not want my car to look funny with huge big sidewalls.
Secondly, if you had to choose for tire brands, which one would you choose? General or Falken?
General was quoted for $397 after mail in rebate
Falken was quoted $420 same size as General
Thanks
Old 05-02-2011 | 04:20 PM
accordguyintake's Avatar
what is stock? why not 205/50/16? unless you want less sidewall than stock..
Old 05-02-2011 | 04:51 PM
Fitcious's Avatar
stock size is 185-55-16
Old 05-02-2011 | 05:13 PM
sooznd's Avatar
Which tire size- (other than stock) would give best mpg?
Old 05-02-2011 | 05:58 PM
Texas Coyote's Avatar
The 205-50-16 is the closest to stock diameter.. The width will create more rolling resistance and that and the additional weight over that of a stock size tire is going to negatively affect fuel economy...
Old 05-02-2011 | 10:29 PM
Fitting's Avatar
185/55/16
http://www.onlinetires.com/user/vehi...allbrands.html
205/50/16
Will give you way more options and better pricing.
Old 05-02-2011 | 10:31 PM
whaap's Avatar
I figure the engineers who designed the whole package is smarter about these things than I am. When I replace my tires they will be the same size.
Old 05-03-2011 | 04:04 AM
konespeed's Avatar
the stock dunlops were pretty crap for the gd, if they're the same for the ge i'd say go for something else. I personally like the kumho ecstas.
Old 05-03-2011 | 04:05 AM
Fitcious's Avatar
^ i partly agree with whaap...but they costs so much. is 195/50/16 going to be a big difference guys?
also, the reason i want to change the sizes is because the stock Dunlops are SO LOUD on the freeway. any suggestions on how to correct this?
Old 05-03-2011 | 04:34 AM
Those are very nice riding, good handling tires that are also very quiet and comfortable riding.
Old 05-03-2011 | 06:05 PM
konespeed's Avatar
Try the kumhos out. 195 will give u more grip if anything. what's the model of the dunlops on ur car? Is it the Dunlop SP something?
Old 05-03-2011 | 07:36 PM
ghettoboy247's Avatar
for the price, i'd def go with falkenz. if you really need tires, hit me up man-714.915.2384. i can install, balance, align, etc... if need be as well.
Old 05-03-2011 | 10:48 PM
Fitcious's Avatar
ghettoboy247: once i find some time out of my schedule, ill let you know.
Konespeed: the stock ones are Dunlops Sp7000 i think. will 195/50/16 make my car look weird? i really dont want to have a side view of my car with HUGE sidewalls from my rim to the edge of the tires..
Old 05-04-2011 | 04:29 AM
Fitting's Avatar
I plotted the stock size, the 195/50, and the 205/50.
Tire Size Calculator - tire & wheel plus sizing
The 195/50 will have a thinner sidewall then the other 2 sizes.
Old 05-04-2011 | 08:22 AM
I was riding on 195-45-16s for awhile.. Throws the speedometer and odometer off a little but increases the rate of acceleration and puts a decent amount of rubber on the road with less weight increase and less sidewall hight...
Old 05-04-2011 | 11:08 AM
sooznd's Avatar
I'd still like to know which tire size would eek out the best fuel mileage:
that is be closer to stock mpg, but provide a smoother ride.
Perhaps a better quality stock size 185/55/16?
I do not want to sacrifice fuel efficiency by going with the the 205/50/16
Old 05-04-2011 | 11:24 AM
Even with the huge increase in power I have at my disposal from supercharging and doing other performance modifications I am still riding on the stock size tires but they are mounted on lighter, wider wheels with a bit more offset.... I prefer doing it this way because of the benefits of a stiffer sidewall due to the increased rim width opposed to a shorter sidewall and the improved ride, handling, steering, braking, acceleration and increase in longevity of the suspension, brakes, steering and drive train components.
Old 05-04-2011 | 05:41 PM
dela's Avatar
for the best fuel economy you want the least amount of rolling resistance.. smaller contact patch... thats why hypermilers over inflate their tires... 175/55/16?
Old 05-04-2011 | 08:56 PM
@70psi!!!
fckn 10 char...
Old 05-04-2011 | 10:10 PM
dela's Avatar
might as well put bicycle tires on the rims... lol\
