Where to install HID?
Old 10-16-2008 | 12:17 AM
FITDragon's Avatar
Yes and no....and it call retrofit......even with retrofit you can still blind the person and plus it depend on the temp you get too...but some HID they have shield to reduce the glare and also it depend on the housing too....
So I'm confused. Is it worth it to change out halogen bulbs for HID's, given that A: You will likely blind other drivers with reflectors based on halogen technology, and B: the difficulty of swapping out the bulbs with HID's?
I've seen proper HID's on the road, with correct color temps (around 6500K), and they're managable. They look bluer than the yellowish tint of halogens, which I prefer.
Old 10-16-2008 | 01:07 AM
gimme's Avatar
Administrator
yes it's worth it IMO. you can see 100% better with them. if you adjust the bulb, there will be minimal glare. i am blinded OFTEN by BMWs that have factory HID.
Old 10-16-2008 | 02:51 AM
azncarbos's Avatar
Whatever gimme Said^^^
but oem max on BMW and MB are 5k and plus it the lens that give the change in colors....
TFREEfit
07-19-2010 10:36 AM
B-Blue
16
02-02-2010 12:43 AM
wobuffet
03-12-2008 04:23 AM
m-man@sbcglobal.net
18
02-14-2008 10:13 PM
Combo
10-18-2007 04:01 AM
