** 9UP GD3 Heart Transplant (build thread) **
i think its time to make another thread about the build progress of my GD3 + K swap, because i feel that the old thread with 50+ pages was just too big and too broad and outdated !....
-Custom fenders done by save on auto body + painted root beer brown
-Custom air ride suspension done by BPG Tuning
-Custom hardwood flooring trunk box done by BPG Tuning
-Custom Air-Brush wood grains on all interior panels done by brinkworth Custom
currently car weights 2900lbs & runs 17.17" 1/4 mile
Engine Spec (as of Jan29)
-K20A short block - M-tech Mugen to balance and blue print
-Spoon thermalstat
-J's racing thermal switch
-S2000 modified oil pump
-Toda A2 cams, and valve train
-Excedy carbon clutch
-Spoon LSD
-ATS 4.7 final drive
-Spoon Throttle body 70mm
-K20A ported intake manifold
-R-crew Intake sump
-Toda head gasket
-Hybird Racing Tucked fuel rail
-Hybird Racing Universal conversion harness
-EP3 cable gas pedal, brake pedals, and custom clutch pedal
-RSX Shifter box custom fitted to chassis + P-spec shifter
-Evolution Performace Custom turbo exhaust manifold (sidewinder)
-Evolution Performace Custom oil catched tank
-Evolution Performace Custom exhaust 2.5
-Evolution Performace Custom intercooler ducting
-Evolution Performace Custom rad support
-Evolution Performace Custom breather outlet
-Garrett T3/T4 hybird turbo
-RC550cc injectors
-all black fuel lines and fittings
-AEM FPR
-Garrett intercooler core build by evolution auto performance
-K-tuned thermalstat
-K-tuned upper coolant hosing
-K-tuned belt tensioner
-Walbro 255L fuel pump
-Hybrid-racing shift cable housing
-Forged racing radiator
Step 1 - Engine out, n some of the swap parts
https://www.fitfreak.net/forums/920366-post2.html
Step 2 - Engine Test Fitted, all hole cut to make room for engine, rad support cut to be ready for custom tube frame, clutch pedal, brakes, custom RSX Shifter installed and DBW deleted !
https://www.fitfreak.net/forums/924030-post22.html
Step 3- Turbo Manifold part 1 !
https://www.fitfreak.net/forums/929834-post44.html
Step 4 - Turbo Manifold part 2 !
https://www.fitfreak.net/forums/934152-post84.html
Step 5 - Turbo Manifold part 3 !
https://www.fitfreak.net/forums/935197-post92.html
Step 6 - Tubed frame rad support and Re-bar
https://www.fitfreak.net/forums/936676-post111.html
Step 7 - Details of the turbo
https://www.fitfreak.net/forums/937990-post125.html
Step 8 - More details on the removable tubed frame rad support
https://www.fitfreak.net/forums/938473-post130.html
Step 9 - More PArts collected
https://www.fitfreak.net/forums/941473-post132.html
Step 10 - Intercooler, IC Ducting, Rad, AC Condensor, Catch Can, Valve Cover
https://www.fitfreak.net/forums/945744-post147.html
Step 11 - Gold plating and Powder coating done
https://www.fitfreak.net/forums/956551-post159.html
Step 12 - Attention to details
https://www.fitfreak.net/forums/957362-post167.html
Step 13 - Racepak iq3 + ATS 9" carbon clutch
https://www.fitfreak.net/forums/957404-post170.html
Step 14 - Feb 12 Small update on putting things together
https://www.fitfreak.net/forums/960875-post177.html
Step 15 - engine bay prep for paint
https://www.fitfreak.net/forums/962665-post179.html
Step 16 - preview of engine bay paint *house of kolor*
https://www.fitfreak.net/forums/967803-post194.html
Step 16.5 - engine bay paint work done by bcautosalon.com
https://www.fitfreak.net/forums/968989-post204.html
Step 17 - Engine in..more parts installed...Some wires done..almost ~!
https://www.fitfreak.net/forums/977366-post211.html
Step 18 - neo chrome
https://www.fitfreak.net/forums/992860-post256.html
Step 19 - engine bay almost done
https://www.fitfreak.net/forums/1000762-post260.html
Step 20 - engine started, un tuned, engine bay 99% done
https://www.fitfreak.net/forums/1003825-post270.html
Step 22 - Tuning @ evolution auto performance in maple ridge
https://www.fitfreak.net/forums/1006597-post288.html
Step 21 - First day tuning @ Evolution Auto Performace
https://www.fitfreak.net/forums/1005680-post279.html
Special thx to Evolution Auto Sound & Performance
Yes....my plates say 9UP
and it's going for heart surgery...
will post more when we cut him open
please stay tune...!
Current mods:
-Full front and rear JDM conversion w/Noblesse Lux body kit-Custom fenders done by save on auto body + painted root beer brown
THE PLAN
Think out side the box ~! my car is AT, the whole chassis is different then MT, all the swap parts on the market now are made for MT fit so most of my swap parts will need to be custom made, like tranny mount, and all the wiring harness. i am not keeping the stock cluster and will be going with RacePak IQ3, we believe it will save us alot of time in turning everything from AT to MT because everything is different. also will be getting the Hybird Racing Universal swap harness to mate with the OEM one. Hasport told me because i have AT...its impossible to do K swap....as again, nothing is impossible !Engine Spec (as of Jan29)
-Spoon thermalstat
-Spoon LSD
-R-crew Intake sump
-Toda head gasket
-RC550cc injectors
-AEM FPR
Oct 7 2010 - Motor out, all the automatic related parts are removed, some holes drilled and no turning back now
electric power steering
some of the parts i got at the moment
M-Tech "Race" Shifter Spring
The best shifter ever, P-Spec shifter
Woodie
My Motor
K20A
Hasport Drive shaft
Woodie
My Motor
K20A
Hasport Drive shaft
