Progress sway bar hardware . . .
Old 05-25-2009, 11:40 PM
Daemione's Avatar
My advice: don't use it, even with the stock springs.
After only 10 days (~1200 miles, 90% highway), my rubber spring mount is already torn through. Here's the bottom of my passenger side lower spring mount:
And from the top:
Is it a huge problem? Not as it is right now . . . but given more time with the Progress supplied bolts, it's not hard to imagine a scenario where the spring would scrape through and cause problems. The good news is that replacement rubber mounts aren't expensive, and I'm still loving the sway bar itself.
Old 05-25-2009, 11:46 PM
Daemione's Avatar
Oh, and here's what the replacement hardware looks like:
Springs seat much cleaner . . . for reference, here's what they look like sitting in/on the Progress hardware:
http://www.daemione.com/fit/progressswaymount03.JPG
http://www.daemione.com/fit/progressswaymount02.JPG
Old 05-26-2009, 12:06 AM
DrKelso's Avatar
What size bolts does the sway bar need?
I bought mine used and it didn't come with hardware and no one seems to be able to help me with it.
The holes on the bar were 1/2" but the holes on the lower spring perch are smaller so I ended up buying 6 sets of incorrectly sized hardware :facepalm:
Any help would be greatly appreciated
Old 05-26-2009, 12:12 AM
Daemione's Avatar
When I was looking for it, a search came up with the answer pretty easily. User sl0wp0k3 had the answer in a thread discussing the old Panducky hardware kit.
6 button socket screws m10x1.5x30
6 m10 washers
6 m10x1.5 nylock nuts
Old 05-26-2009, 12:18 AM
trancedsailor's Avatar
Yeah I was just going to be looking for a thread like this tomorrow. I've had my swaybar laying around for over 6 months and I finally want to put it on lol. Thanks for the info, Daemione!
Old 05-26-2009, 02:23 PM
FitVic's Avatar
good info i bought my hardware from another member which he got from ace hardware. it would have been easier to just know what i needed to get it and stuff. but i ended up giving the member a few extra bucks on top of what he paid for getting me the stuff lmao
This is great info for a lot of other users that have coilovers and RSB
Old 05-26-2009, 07:16 PM
Daemione's Avatar
Yeah, I'm looking at coilover's in the near future for myself. And like I said, even on stock springs I'd highly recommend the alternative hardware.
Old 05-26-2009, 07:20 PM
Progress definitely were morons when they used that hardware. Did they even test out the swaybar????
Old 05-27-2009, 09:59 AM
Fitting's Avatar
Daemione where did you get your replacement hardwares?
Old 05-27-2009, 12:54 PM
Daemione's Avatar
fastenal.com
Old 05-27-2009, 03:49 PM
Fitting's Avatar
^ thanks !!
Old 05-27-2009, 05:03 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
Hey! Go to ace hardware you can get it there.
Old 05-27-2009, 05:38 PM
thanks
Awesome pic, Bitoy. Makes me miss the navy ;/
Old 06-06-2009, 06:38 PM
nobody seems to sell the button-socket screws around here. I need to buy them online
Old 06-06-2009, 06:43 PM
this is what I need, right?:
Product Details | M10-1.5 x 30mm ISO 7380 A2 18-8 S/S Button Socket Cap Screw | Fastenal
$11 shipped. Ugh. I need to return the hex-type ones I bought KNOWING they wouldn't work. I already have the washers and nuts. Hm. Guess it's worth it
Nevermind I bought the steel ones. Saves me a few bucks. Not worried about it rusting. I won't be taking this off.
Old 06-07-2009, 03:03 AM
kylerwho's Avatar
spoon fed
uh..... guys you should just weld the bar on and forget about that hardware crap. that is what i did and i hear no noises and my springs have set properly with no interference from bolts.
Old 06-07-2009, 10:17 AM
some of us don't know how to weld, i.e. ME lol
Old 06-07-2009, 11:02 AM
Daemione's Avatar
That'd be fine if I was 100% sure I'll never want to return the car to stock to sell it. I also like to keep my options open when it comes to suspension upgrades . . . e.g. when I get coilovers in the near future, I may not want the bar on there at all - depends on what the balance is like.
Old 06-07-2009, 11:15 AM
you'll still want the bar. I want it on and I have coilovers. Just waiting on bolts in the mail. I want the t1r front sway and underbrace as well. The stiffer the better.
Old 10-08-2009, 09:22 PM
92h22civichatch's Avatar
weld??
isnt it sprung steel? as in the rear control arm? i mean welding sprung steel will kill the temper and your sway bar will become brittle and likely break
Quick Reply: Progress sway bar hardware . . .
