3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Camber Issues - not enough negative!
Old 05-09-2019 | 05:18 PM
psamtik's Avatar
I added camber bolts to my fit and am still getting horrible outer shoulder wear on my front tires. I drive my fit somewhat aggressively into the turns, but is this something the fits are known for? I've never killed the shoulders on tires so quickly!
Old 05-09-2019 | 09:34 PM
96_lxr's Avatar
What kind of camber values is the car currently set at and are you sure it’s not toe in that might be chowing the tires?
Old 05-10-2019 | 10:15 AM
evilchargerfan's Avatar
ill make an early prediction .... its the toe ... that is killing your tires
but ... i'll play along. what is camber at now? and.... what are you trying to get it to?
Old 05-12-2019 | 02:04 AM
hasdrubal's Avatar
Did you recently lower your car? I did my spring/shock/camber bolt install in my garage, and it was surprising how much the toe changed.
whitefitsport
10-02-2018 10:54 PM
ciref8
10-17-2014 12:31 AM
gnarlyj3rick
04-16-2013 01:33 AM
Green karma
19
01-08-2013 11:53 AM
mkane
07-04-2012 10:35 AM
Quick Reply: Camber Issues - not enough negative!
