Front pads and rotors
Getting ready to do my front brakes. I didn't find a thread specific to this procedure. Does anyone have information I would need, like torque specs, etc.? Thanks in advance.
I plan on buying new rotors.
On second thought, maybe I can just swap out the pads.
Thoughts?
Thoughts?
Just about 80,000. Guess I'll just have to see what they look like. I'm careful not to overheat them.
Rotors are cheap. They're $40 each where I live. Get an impact driver to get the little phillips looking screw out of the rotor. There isn't a need to reinstall that little screw, its meant to hold the rotor in place on the assembly line.
If I recall correctly my 2015 Fit didn't even have them on both rotors. You can often get them out with the correct size bit, and a breaker bar. I'm not sure what kind of head they have. What looks like a Philips head may be some other kind, a Japan something or other kind of head.
Japanese Industry Standard (JIS)? I doubt it's necessary for brake rotor set screws. Especially when replacements are easy to find if you round one out. I just never tighten them past snug and I always add some anti-seize to the threads first. They always come out with little to no force like that.
p1driftfiend
14
12-07-2008 10:51 AM
