Rear View Mirror Height Tilt Adjustment
Greetings, I'm the proud owner of a new 2017 Honda Fit EX-L. My wife and I love the car, with a couple of minor niggles, and one of them is the following:
I can't adjust the rear view mirror tilt sufficiently to view the whole of the back window when I'm sitting fully upright in my seat. This is despite lowering the seat all the way to the floor (our other complaint is adjusting the seat between my wife and myself; she's 5'1", and it requires *19* handle pumps to switch between the seat heights we find comfortable). I'm 6'1", a little taller than average, but not NBA material.
I see plenty of people posting that, for example, they are 6'4 or 6'7, and the Fit works great for them due to the high roof line. I have to imagine that I could find some complaints about the rear view mirror if this was a common issue.
I'm wondering if I should go to the dealer and ask them to adjust the mirror placement or place a shim under the bottom edge.
Thanks in advance for any advice you may have!
Cheers,
Nick
Cheers,
Nick
You need two Fits to resolve the seat adjustment issue, otherwise you have to continuously "pump" 19 times when you change drivers. In regards to the mirror, the "day" position is when the mirror flipper is flipped to the rear. The "night" position to avoid glaring headlights is flipped towards the front windshield. Do you have the mirror in the "day", the default position?
RE: the day night position setting, it's in the day position (flipped down). I'm very used to toggling this, as bright headlights behind me really bug me. I believe you have reversed the position on the switch in your description, though; day position is with the switch flipped down / toward the windshield, to view an image of the rear directly through through the rear hatch. Night position is flipped "up", or pulling the the switch toward the rear of the car, to view using the reflection off the rear headliner / ceiling instead of looking through the rear glass.
Cheers,
Nick
I have not had this issue with rear view visibility through the rear view mirror, and have not heard of anyone else with this issue on this forum.
You cannot sufficiently tilt the mirror up enough to see the whole rear window, which means you see too much of the rear seats, or you cannot sufficiently tile the mirror down enough to see the whole rear window, which means you see too much of the roof liner?
Maybe the mirror is stuck on the windshield at the wrong height, or something is wrong with the actual mirror. Since this is a safety issue you should go back to the dealership and get this corrected.
I can't adequately tilt the mirror up. So at maximum tilt, I cannot see the top third of the rear glass in the rear view mirror (I can see the lower 2/3rds). It does adjust, just not enough. I'm planning to hop in a floor model when I'm at the dealer and confirm that I can adjust the mirror properly in that; it'll be good ammo if the service department claims that the mirror is installed correctly.
Measuring from the roof liner by rear view mirror is 6 3/8" down. The mirror is at the bottom of the dimpled design. You should measure yours.
Perhaps the mirror is upside down? Maybe try to turn it 180 degrees and see if this help? Then again the flipper lever would be on the top side of the mirror vs the bottom.
RE: the two Fits, of course, why didn't I think of that!
Cheers,
Nick
Cheers,
Nick
Just in case it hasn't been mentioned, the mirror adjusts not just by maneuvering the mirror itself, but also the "stalk" that attaches it to the windshield (can be raised quite a bit from bottom position ....can't tell from original post if yer just tilting the mirror or adjusting the "stalk" as well ....it should work fine with some fine tuning, yer not THAT tall
I did not know this. I'll have to see this tomorrow.
I am 10" taller than my wife. To simplify matters we leave the driver's seat in the most elevated position.
In my defense, I tried to move this stalk previously and it didn't budge at all. From a quick glance I just assumed the stalk was molded in an angled shape, and didn't notice that it had a ball joint on the windshield mount side. After adjusting the stalk tilt, which required a TON of force (no joke, thought I was going to snap the mount off), I can now easily see out of the back window. The mirror side adjustment alone, now that the stalk angle is adjusted, works fine for both my wife and I.
And in other happy news, now that I don't have to lower the seat all the way to have a hope of using the mirror, just a few pumps/pulls of the height handle are necessary when my wife and I switch seats. Win win!
Really appreciate the thoughts and assistance from all.
Not a problem, glad that was all it took ....have had mine a year, and I do remember it being pretty tough to move at first....
