2016 Fit EX 6MT Transmission Noise
Old 10-12-2016 | 10:16 AM
Bassguitarist1985's Avatar
The audio is compressed even at 720P. I hear what you are saying. I believe the sound is normal for the type of transmission you have. I don't have any whine sounds when deccelerating with my 6MT, except in reverse.
Old 10-12-2016 | 10:49 AM
tbFit's Avatar
Originally Posted by Bassguitarist1985
... I believe the sound is normal for the type of transmission you have. I don't have any whine sounds when deccelerating with my 6MT, except in reverse.
Confused... He has the same 6MT as you? I was the one that mentioned hearing a similar sound in my CVT. I probably should have refrained from commenting on this thread. Doh!
Old 10-12-2016 | 12:18 PM
fitchet's Avatar
Good Luck with the factory rep.
I can't really tell from the audio whether I would consider that sound beyond the normal. I think every manual transmission I've ever had made some level of auditory "change" when decelerating. Which usually I actually liked. But hard to tell if yours is normal or a sign of something abnormal.
IF...Honda decides to replace the transmission, I'd accept that. They should be able to do that easily and I wouldn't think that diminishes the "integrity" of the vehicle.
But lobby for a resolution you are going to be comfortable and happy with. And Good Luck.
Old 10-12-2016 | 06:36 PM
MelR's Avatar
Originally Posted by Ciscofit
UPDATE:
Follow the link to listen to the decal trans whine of my 2016 EX 6MT. Recording was made using a Tascam DR-2d professional audio recorder located on the front of the passenger seat. The whine continues unchanged while decelerating and downshifting through 6th 5th 4th only. No whine from 3rd 2nd 1st or when accelerating or maintaining a constant speed in any gear. I have never heard a Honda manual transmission make this noise, and I have owned many.
What do you think? The ambient sound of the whine is much more evident in the vehicle interior than the recording demonstrates.
My appointment with the Honda Factory Rep is next Monday. I will be discussing your responses in general with that person.
https://youtu.be/oDb6KZEDLzE
Sounds like mine.
Old 10-13-2016 | 02:01 AM
Fuelish's Avatar
Our '15 6 spd doesn't sound like this, unless I've driven too many manuals over too many decades that it's become "normal" .... but...yeah, I hear what yer talkin' 'bout, and no, ours does not whine like that, just "normal" whine, if that makes sense
Old 10-13-2016 | 05:43 PM
CommanderSlug's Avatar
That's some spooky Halloween sound you've got there. Maybe you have a secret sleeper turbo stuffed somewhere under the hood.
Are you sure it's the transmission? Maybe it's something else. Who knows. In my case, my 6MT now has 45k miles under its belt with no airplane sounds whilst engine braking.
Old 10-21-2016 | 05:23 AM
MelR's Avatar
[QUOTE=Ciscofit;1356385]UPDATE:
Any resolution??
Old 10-25-2016 | 05:34 PM
MelR's Avatar
Wanted to bump this up to see if you'll let us in on what the Honda Factory rep had to say about your whine??
Tofu
09-04-2018 12:16 PM
FTL
11-02-2016 11:33 AM
phinegan
07-14-2016 06:25 PM
csb101
05-23-2016 09:44 PM
Ciscofit
04-19-2016 09:18 AM
Quick Reply: 2016 Fit EX 6MT Transmission Noise
