Tire size recommendation for 15x6.5
Old 02-17-2016 | 01:30 AM
MrDucky's Avatar
I was thinking of getting a set of Enkei RPF1 Type II Wheels 15X6.5 / 4X100 / ET35
What tire size and brand would be recommended?
I am primarily concerned with increasing ride comfort, acceleration and reducing road noise.
I know a lighter wheel and taller side wall should help out with this but I don't know where to go from there since I am fairly new to all of this.
Any help would be greatly appreciated.
Old 02-17-2016 | 02:25 AM
KikeDiaz's Avatar
Tire or rim?
Tire CR always recomend michellin defender. for the rim both look awesome and the brand is pretty good.
Old 02-17-2016 | 02:40 AM
MrDucky's Avatar
I am pretty set on getting these rims. I just need to know what size tire will fit. I want to keep the diameter as close to OEM as I can so the speedometer will read correctly.
Will 175x65x15 size tires fit on this rim?
Old 02-17-2016 | 09:07 AM
Carbuff2's Avatar
You can answer your own question by plugging the proposed sizes into a Tire Size Calculator:
Tire size calculator
Old 02-17-2016 | 12:18 PM
KikeDiaz's Avatar
175/65R15 tires | Michelin Tire Selector
Or this page. I already enter the measurement. Based on what I have read on the past michelin energy saver are not that good in water and patholes so be aware
Old 02-17-2016 | 01:20 PM
GeorgeL's Avatar
Stock tire on a LX is a 185/60R15. The LX has a narrower 5.5" rim so you might want to go to a 195/60R15 on your new rims to protect the edges a bit better. The 195 size would be about 2% larger in diameter which would actually make a Fit speedometer just about dead accurate, since the stock speedo reads about 2% high.
I've been running Goodyear assurance FuelMax tires on my cars for several years and find them to be excellent. Good economy, long wear, and smooth ride. They are _not_ for Ricky Racer types, though!
Old 02-28-2016 | 11:26 PM
MrDucky's Avatar
Does any one know what off set will be better? This rim comes in 35 and 41.
Old 02-29-2016 | 03:29 AM
GeorgeL's Avatar
Stock is 53, so the 41 would likely be the best of the two. You might have some clearance issues so check before you buy.
Thorzdad
02-02-2014 09:56 AM
Splater
03-15-2013 01:51 AM
fit1234
08-28-2010 01:56 PM
dcmcelreath
06-01-2008 07:12 PM
Sugarphreak
05-24-2008 10:10 AM
