Piece of Plastic in Rear Wheel Well: What is it?
2016 Fit, Canadian base LX model. I have a "Z" shaped piece of plastic in the rear wheel well, just forward of the rear wheel, on both sides. The plastic is flexible and bolted into the frame with one bolt and one push connector. It is strong, and reinforced with ridges. What is it? What is it's purpose? I have no wheel well liners.
2016 Honda Fit, Canadian base, plastic in right rear wheel well, forward of rear tire. What is it?
Honda calls it a "strake" and it's #14 and 15 here Toronto Honda Parts - Parts List
They pretty much deflect some air away from the tire, it's more aerodynamic than letting the tire plod its own way thorough the air.
Check out a CRV theirs are a quite a bit longer but IDK if they would attach to a different car easily.
Thanks for the info. You know your aerodynamic bits.
source
Originally Posted by sparky5501 from insightcentral.net
Well, strakes are at the front of the wheels under the bumper area, unlike "mud flaps" which are at the rear of the wheels. The Strake helps deflect the air flow around the tire. They are standard from the factory, but might be installed after the dealer gets the car, to prevent injury while on the transport, cos they hang low. They are not an accessory. My Insight has them under the front bumper at the wheel opening. Yes they help with the under car aerodynamics. Clearance... Well, you can't go driving over curbs, and most automotive lifts will scrape the snot out of them, other than that you don't notice they are there...
tubegeek
08-18-2008 10:12 AM
jits14
14
09-05-2006 09:32 PM
