Fuse Box A????????
Old 05-18-2015 | 01:44 PM
wxgeek's Avatar
Fuse Box A????????
Have a 2015 Honda Fit,bought in Jan. Misting function on the windshield
wipers stopped working. Check reservoir and filled it up. No dice.
Don't hear the motor running. So I want to check the fuse. Owners manual
says its in Fuse Box A. Fuse Box B is reachable but Fuse Box A is behind
the lower dash cover. Owners manual does not say how to remove this
cover. Tried to locate a honda service manual on Ebay, Helm for the 2015,
but no dice. Latest service manual I see is for the 2012. Do you have to
wait like 6 months/1 year for 2015 service manuals to appear?
Now some may be asking, why not take it into the dealer and have them
fix it? Well I'm not sure that this is a warranty item and the dealer is a 64
mile round trip. While I do take it in for standard warranty service, I
thought I would be able to simply check this fuse to see if the fix was that
simple. But...Honda engineers in their not so brilliant wisdom decided to put
a fuse panel where it is essentially unreachable by the owner. So unless
there is some secret unlocking mechanism for the lower dash panel...I
guess I'm screwed.
Thanks for reading!
Jim
Old 05-18-2015 | 02:00 PM
CN_Fit's Avatar
guess I'm screwed.
Thanks for reading!
Jim
I don't get it, A is under hood and B is under steering wheel? The legend is on a sticker under the steering wheel, on the stem wrap casing itself?
Old 05-18-2015 | 02:20 PM
Bassguitarist1985's Avatar
Its a 15 AMP fuse under the drivers side dash. Left side, its fuse# 22. Fuse BOX A. You can look underneath the steering column for the key legend where all the fuses go. If the fuse is blown it will be easy to fix. if it blows upon inserting a new fuse then there is a short somewhere.
EDIT: Fuse Box B has a black cover on it. There is nothing you should have to check there. if you did, then I'd say bring to a dealer as those are high amperage and if they are blown there is likely a bigger problem with the car.
Old 05-18-2015 | 04:00 PM
wxgeek's Avatar
Yeah its in Fuse Box A...which is behind the lower dash panel. Not sure
how to remove the dash panel. Dont want to tear anything up...but I'm not
sure how its attached...with plastic body screws maybe? Thats why
I was looking for a repair/service manual to tell me how to remove the lower panel.
Jim
Old 05-18-2015 | 04:30 PM
There is no need to remove the lower dash panel, you can get to it by going right underneath the dash.
Old 05-18-2015 | 06:32 PM
wxgeek's Avatar
From what I understand...the fuse box that is visible under the dash is
Fuse Box B(according to the owners manual). The fuse panel located "behind" the lower dash panel is Fuse Box A...which is where the offending fuse is located. However, this may all be for naught, since I don't know what caused
the fuse to blow...if it did actually blow.
Jim
Old 05-18-2015 | 06:48 PM
Uncle Gary's Avatar
Despite what the owners manual seems to imply, there is no "panel" to remove to access fuse box "A". It's behind the dash, but if you stick your head under the dash and look up, you will see it in all its naked glory. Just below fuse box "A" is fuse box "B", under a snap on plastic cover.
To further confuse matters, Honda calls the two fuse boxes under the hood "fuse box A" and "fuse box B", also.
Old 05-21-2015 | 04:05 AM
DWils's Avatar
Seems like a lot could be cleared up if someone were to take a picture of the fuse box(es) under the dashboard.
Old 05-21-2015 | 10:33 AM
CN_Fit's Avatar
Tbh, there are only two fuse boxes that I know of (irrelevant atm a or b). One is under the hood with legend on the fusebox cover and other is above the pedals, below the dashboard and the legend is on the steering column cover. It couldn't be simpler than that, both are easily accessible.
And the drawings of the locations are in the owners manual.
Old 05-21-2015 | 10:40 AM
At about 1:29 in i show you where I was connecting my tow light harness into the fuse panel. I'm telling ya its impossible to miss.
wxgeek
07-11-2017 10:32 AM
SilverEX15
07-30-2015 04:30 PM
proaspen
08-14-2012 10:00 PM
kenchan
12-23-2007 10:53 AM
sLiVeRwOrM
05-13-2006 12:02 PM
