Mounting Dashcam
Old 02-12-2015, 02:23 PM
Fit Charlie's Avatar
Originally Posted by briank82
Is there no straightforward way to hardwire a dash cam?
Add a fuse. Then just run the wire up around the A pillar molding.
Old 02-12-2015, 02:25 PM
What do people do if their camera had an impact type setting that could record when the car is off? Or are there built in batteries that handle that?
My E46 M3 had a radar detector hardwired into the wiring used for a button used for a garage door opener button near the interior lights (by rear view mirror) that made a hardwire super easy and nifty. Is anything like that possible?
Yes. Purchase an add a fuse kit, connect to the aux fuse panel under the driver side dash, and connect that to a 12v accessory adapter which the cameras adapter connects to. yes the camera has its own batteries but its way too small to last any significant time. That panel is ACC on only, meaning it is only energized with the ignition on.
Old 02-12-2015, 09:16 PM
GoBucky's Avatar
Sorry, unrelated, but I owned/drove an E46 M3 for about 7 years. Sweet car, bright red convertible, 6mt, 2004my, boy I miss it.
Old 02-20-2015, 01:15 AM
briank82's Avatar
I know the feeling. I had mine for a year before I totaled it in a somewhat-freak accident.
Mine was supercharged with methanol injection and nitrous. Nearly 500 rear wheel horsepower without the nitrous … and now I drive a Fit. Ha!
Man I miss that car! They're crazy cheap now, but you better be prepared to deal with maintenance issues.
Old 02-20-2015, 07:29 AM
SilverEX15's Avatar
I bought a separate fuse block that holds six fuses. I ran a wire directly from the battery to power it.
Amazon.com: Bussmann BP/15600-06-20 Quick Connect Fuse Block: Automotive Amazon.com: Bussmann BP/15600-06-20 Quick Connect Fuse Block: Automotive
Old 02-20-2015, 01:02 PM
Those are nice!
Old 02-21-2015, 04:01 PM
Here is a picture of how it looks. Its all hidden under the dash, and the fuse is piggybacked on an ACC ignition on circuit on the AUX fuse panel
Old 02-21-2015, 04:23 PM
SilverEX15's Avatar
Looks good.
Old 02-22-2015, 08:00 PM
m_x's Avatar
m_x
m_x is offline
Looks good.
Into which slot on the auxiliary fuse panel do you add the fuse?
Old 02-22-2015, 09:02 PM
Any one of them where it is only on with the ignition on. The camera is very low power I used a 5 amp fuse.
Old 02-22-2015, 10:35 PM
hogwylde's Avatar
The Fit has those black dots on the windshield behind the rear view mirror, so a suction cup won't stick there. Because of that, I mounted my dashcam on the far right side of the dash. It works fine and shows what's up ahead, but the video is upside down, since the camera is mounted upside down from the position it was intended to be in if stuck to the windshield.
How do you mount the camera on the windshield with those black dots? I thought of using Velcro to mount a piece of plexiglass and attaching the suction cup mount to that.
Here's mine. I also used the little window for my GPS.
  #32
Old 02-23-2015, 10:52 AM
m_x's Avatar
m_x
m_x is offline
Any of them? So if the slot is occupied I can take that fuse out and add the fuse kit there, and then just put the removed fuse back into one of the add-a-fuse slots and put the 2A fuse for the camera into the other?
I guess what I'm really asking is if there is a maximum rating for a given fuse slot on the aux panel. I know I'm only adding 2amps of draw, but are the slots rated for a certain draw/is it possible to overload individual slots?
I'm stupid
Edit: According to page 425 of the manual, slot 39 is defined as "Option" and rated for 10A. Would that be a suitable place to connect the added fuse?
  #33
Old 02-23-2015, 12:14 PM
it is possible to overdraw a single fuse "slot" on the aux panel. The panel itself has a master main fuse at 40A I think. The biggest fuse size is 20A.
Yes slot 389 will be perfect for the camera
For my situation I've added a ton of stuff. Camera, trailer light unit, heated side mirrors which it was meant for but no stock wiring on the EX, and finally the brake controller. Instead of crowding the AUX panel with Add a fuse kits, I got a 6 position AUX fuse panel CONNECTED to the AUX panel of the FIT via TWO add a fuse kits with 20A each for a total of 40A. This prevents overloading a single fuse slot.
The biggest draw on the Aux panel is the brake controller for towing. It needs a 30A fuse. Though I highly doubt I will need that much and it should not go anywhere above 20A.
***Connecting loads directly to the battery means also bypassing the ELD thus why the AUX panel made the most sense to add stuff. Drawing from the AUX panel means the ELD will sense the load an compensate with the alternator demand.
  #34
Old 02-25-2015, 10:28 AM
ai4px's Avatar
I"m a little late on this thread.... can the dots really be scraped off? I'd love to mount my camera above the mirror. Lots of red light running going on in my town lately.
FWIW, the Mobius action camera is a great cam and if you swap the battery for a super capacitor, it'll last forever in the heat of the summer.
  #35
Old 02-25-2015, 11:05 AM
Fitmo's Avatar
I was kidding about scraping off the dots. I would not do that.
  #36
Old 02-26-2015, 12:48 PM
2007Fit5AT's Avatar
You mount it on the dashboard with this excellent mount I've been using for some 5 years now.
FAT GECKO SUCTION CUP MINI CAMERA MOUNT DDMOUNT-MINI#
  #37
Old 02-26-2015, 01:27 PM
SilverEX15's Avatar
I have a good dash mount, but the video is upside down because the camera is designed to mount on the windshield, so it would be inverted. When the weather gets warmer, I'm going to use the 3M double-sided tape between the windshield and the suction cup.
  #38
Old 02-28-2015, 12:27 AM
2007Fit5AT's Avatar
What camera???
That's what I've been using since March 2010:
Sony HDR-XR100 80GB High Definition Handycam Camcorder HDRXR100
Plus a 32GB memory card and 30mm/37mm Wide-End Conversion Lens - VCLHGE08B Review | Sony Store U.S. - Sony US
Still runs very smoothly.
All the best out there.
Chris
gkitf16
05-22-2016 12:04 PM
fuzzybabybunny
05-18-2011 12:28 PM
GrocerySnake
07-25-2010 10:51 AM
asanz
09-01-2009 03:00 PM
runbikerun
01-13-2009 01:16 PM
Quick Reply: Mounting Dashcam
