Playing Music from a Flash Drive
A couple of weeks ago, I inserted a small flash drive into the front USB slot, and I could play music from it. I recently updated the music on it, but I can't see a way to access it now. What am I missing? "Source" shows me AM, FM, Bluetooth, and iPod.
Basically, insert the flash drive and select it with the Source button. And when that doesn't work - as it did two weeks ago?
Or try your query on one of these previously well-established, highly informative threads:
https://www.fitfreak.net/forums/3rd-...ash-drive.html
https://www.fitfreak.net/forums/3rd-...ory-stick.html
https://www.fitfreak.net/forums/faq....faq_vb3_search
As tmfit suggested try the other USB in armrest: if audio system recognizes something is connected then you have issue with other port; if it doesn't recognize a device connected on either port you have bigger issues.
On the other hand if you DO show connectivity on both ports (but won't play files) then you just have an issue with the thumb drive ... maybe f-ed something up when updating the drive. Try wiping out the drive: delete everything.... maybe even re-format, start from scratch. Then move the files back to the thumb and try again.
Good Luck! Post update of your findings
It was my stupid mistake. I have a FitBit that uses a tiny USB plug-in, and it looks almost exactly like my tiny flash drive. That's what I inserted into the slot in my Fit. Of course it didn't work. Now I'm back to normal.
Mini
I got one of these little guys. It's so small that the USB door can close over it.
Amazon.com: SanDisk Cruzer Fit 16GB USB 2.0 Low-Profile Flash Drive- SDCZ33-016G-B35: Electronics
BTW .. what is a FitBit?
Fitbit is Awesome. I use the FitBit One and its just a little thing that you clip on your belt that's pretty simple in its own right. It counts steps. BUT since its teamed up with their software you get a lot of data. Calories burned, step goals, floors climbed, and sleep tracking. Being able to see my sleep data before and AFTER my baby was born is worth laughing about. End Rant.
I used to enter all the food I ate on the FitBit site, but that got to be a nuisance. Mine doesn't track my sleep, but that's okay, because I'm usually asleep then, anyway.
dontaskbrad
06-25-2010 12:29 PM
