Disable DRL.
Old 09-01-2014, 11:39 AM
MTLian's Avatar
Originally Posted by andre181
Yeah. I always use mine but its a habit from my manual days.
Not sure why people don't though. I'd rather rely on the brake than the transmission to make sure the car doesn't roll away. Those parking pawls break...
I dunno about auto but on a manual, I have much more faith in the transmission holding my car than the hand brake. On very steep hills you really have to crank the sucker to hold the car. Then again, I could tighten the cable...
I always park my car in gear on a hill (MT). I use the brake also but would feel comfortable only using the tranny.
I never use the hand brake on auto tranny because it's always someone else's car and I know that if I put it on, there a good chance the owner will end up driving around for a few minutes with the hand brake on before realizing! I'm glad my ole GD3 beeps when you try and drive with the handbrake on. I've occasionally forgotten it when waiting at a very long red light.
Old 09-02-2014, 08:06 AM
TofuShop's Avatar
Originally Posted by TofuShop
Can someone post a pic of which is fuse #25, please? There are two fuse boxes (one covered, one uncovered). The covered box only shows a diagram for 1 through 15. Should the larger fusebox on the left have a cover as well...?
Can someone who's pulled the fuse comment, please? thanks
Old 09-02-2014, 10:53 AM
payluder's Avatar
The fuse #25 is in the uncovered fuse box. If you look under the car steering wheel column there is a map of the uncovered fuse box and shows the location of the day time running lights which is 7.5 amp. I'll take a picture of the location and the fuse that was pulled when I get home unless someone beat me to it.
Old 09-02-2014, 11:19 AM
nullxposur's Avatar
This is a crappy picture because I'm too lazy to go take a pic. It's in the #25 fuse right below the steering wheel in the uncovered fuse box. The covered fuse box under the steering wheel holds separate fuses; the fuse map on that covered fuse box is for those fuses inside it only, not for the uncovered one. If you look at the manual, you can see the fuse map and it's #25. The first fuse is a 20A iirc. You then count down with 7 fuses per column. Count till you get to #25, a 7.5A. You can use the fuse remover that's inside the engine fuse box if you don't have one.
Old 09-02-2014, 11:45 AM
TofuShop's Avatar
Thanks so much guys
Old 12-31-2014, 08:19 PM
lazyd0c's Avatar
where exactly is the fuse remover? I located the uncovered fuse box but there's no tool there to have the fuse removed..?
Old 01-01-2015, 06:30 AM
Ex-MA Hole's Avatar
Fuse box under the hood.
FitBiscuit
09-21-2017 07:57 AM
hnickm
11-28-2015 08:29 PM
j5ive
Canada Fit Forums & Clubs
18
09-16-2014 01:52 PM
alanchan
06-01-2012 12:05 AM
rickycbrjazz
03-15-2011 01:15 PM
Quick Reply: Disable DRL.
