Oil Light (Blue)
Oil Light (Blue)
Weird thing happened today where I started my car and the oil light was on (but blue).
It was on for probably 1 minute once from when I started it to when driving for a little.
The car was parked for the work day 9am to 6pm.
I looked at the manual and I believe it was a notification for the oil temp being too cool? Anyone ever experience or know of anyone?
Steel Grey - EX
Steel Grey - EX
It was probably the coolant indicator that glows blue until the engine warms up a bit (approximately 1-4 minutes depending and temperature and the engine load). Oil light should be red. Do not worry. Pay close attention though.
Honda has been using the blue coolant temp indicator for a few years now. First one I remember was on the then new 2007 Fit. It saves gauge cluster space by not having a germinate coolane gauge on the dash and is less prone to failure.
The gauge indicates the engine is not at optimal operating temperature yet.
You can drive the car with it lit just take it easy until the light goes off.
Mine has been on every morning when I start it, and I live in south Florida. I've only had the car since Sunday though. The first day I waited maybe 30 seconds and it turned off. The other two day I didn't think about it and it went off before I was out of the driveway.
If it is calibrated to go off at 127F, I'm assuming it will be on for a few seconds anytime the car has sat for a long period of time.
I get this often when i start up on my 09 fit sport. I dont think its an issue. I would check in your manual.. But i believe its just you telling you the engine is cold. Also it may be that your oil is going to be do for a change soon. I know mine is about due.
hope i helped a bit
hope i helped a bit
hope i helped a bit
hope i helped a bit
acidic@tokyo.com
05-04-2005 11:16 AM
