Somebody Explain to me: CVT, Sport Mode, Paddle Shifters
Old 03-25-2017 | 08:36 PM
Japan Tragic's Avatar
Originally Posted by fitchet
"due to the CVT effectively being one gear that can change ratio from low to high range it gives a particularly bad feeling to drive... similar to a slipping clutch."
That is opinion not fact.
It's all kind of what you are use to, and or grew up driving.
I learned on a manual...and then later have driven standard automatic transmissions.
But I like the CVT. I think it improves fuel efficiency, and the absence of shift points can just as easily be defined as "smooth" driving, I think more precisely than comparing it to a "slipping clutch".
To each his own. But I don't think it fair to characterize a CVT as having a "Bad Feeling To Drive" or being "Less Enjoyable To Drive".
coincidently sold my GK5 Fit recently for another daily, I hated the CVT so much the #1 priority for the next car was manual, followed by power/economy/practicality etc LOL. It is definitely `to each his own` but I grew to hate the CVT so much I dont think Ill be going auto again for quite some time, maybe never!
Old 03-26-2017 | 01:06 PM
dwtaylorpdx's Avatar
I've yet to drive a cvt I liked.. I even prefer the 5 spd auto in my Fit to them.
Haven't got to drive a honda CVT for any length of time but the rubber band snowmobile feeling tranny I just hate. I had several nissan company vehicles, that had the CVT, was fine around town, but on the freeway on hills just hated the lack of control of the enigne rpms and the poor engine braking characteristics.
The CVT works by slippage, the "belt" has to slip in the shivs for the ratio selection. They are also basically not a rebuild-able transmission.
If you are a relatively relaxed driver I think the CVT would server many folks well, I just drive too many open road miles and the fit is not my go-to car for that. When I do its nice to have real engine braking on 20 mile down hill stretches out of the mountains.
Drive what you like,,, Not what I like.. LOL
Old 03-26-2017 | 07:11 PM
2Rismo2's Avatar
I was able to drive the back of the dragon and in sport mode a few months ago, there is plenty of engine braking. If you want a little more, just hit the left paddle shifter and you've got it on demand.
Let's be honest. 95% of fit drivers just wanted an inexpensive car to get them from point a, to point b so they bought the CVT. The other 5% wanted a more sporty stick shift car but couldn't afford something better lol.
I'm a 95%er. My fit is a commuter car. On the occasions I get a twisty section, I can use sport mode. The rest of the times, regular drive mode takes care of everything else.
Old 03-26-2017 | 07:47 PM
this is exactly right, when replacing the fit we found just how good its use of cabin space was with larger cars not being able to match it. Economy, reliability and everything practical it was unfortunately totally awesome. So giving it up in the name of a little less boringness/power meant a few unwanted compromises.
If they made a fit with 180~200hp I would still be driving one (manual that is LOL).
Old 03-26-2017 | 07:59 PM
stembridge's Avatar
Can somebody explain to me what exactly is CVT and how it differs from automatic. Will having a car with CVT increase maintenance costs?
I'll tread where angels fear to go and add my own take on your questions...
First, here's a good explainer (among many on the interwebs): Why CVTs are Awesome Transmissions
Also, what is sport mode? I assume sport mode and the paddle shifters go together? Can we shift to sport mode while driving on the highway? or do we have to be at a full stop in order to change to sport mode?
Sport mode simply changes the transmission ratio such that the engine is turning higher RPMs at a given speed (same as shifting to a lower gear on a manual). Since the engine makes more HP (up to a point) at higher RPMs, you have better acceleration, etc.
You can shift from D to S and back any time you want and it won't hurt anything, although if you do go to S at a high speed, the engine's really going to rev up, which may catch you by surprise the first time you try it.
If I use the paddle shifters, will I cause any damage if I downshift while at a highspeed on the highway (whether by accident or by ignorance)? Can the paddlshifters be used to improve performance on the highway the same way a manual transmission would allow?
As others noted above, you can use the paddles with either D or S. In D, they will temporarily change your ratio up or down, returning to normal CVT operation after a few seconds or when engine RPM returns to a certain range. I use the paddles in D to engine brake when coming to a stop, or when descending a hill, for example. You can also "up-paddle" in D, but there's usually no reason to do so - it would be like shifting to too high a gear on a manual.
When you first shift to S, the CVT continues to operate in "continuously variable" mode, albeit with higher engine RPM ratios. However, as soon as you hit the paddle (either up or down), it will move to one of seven pre-programmed ratios ("gears"), and will stay there until you paddle up or down again, or if you hit redline or drop to too slow of an RPM ("lugging the engine"), at which point it will automagically go to the next appropriate ratio.
I learned after a while that "blipping the throttle" like you would do with a manual makes for a crisper transition between ratios, otherwise, the "upshifts" feel slow and mushy ("downshifts" aren't as mushy-feeling). You can make it sound pretty darn close to a manual using this technique.
At highway speeds, normal CVT operation will actually give you a lower RPM than 7th "gear" with the paddle, so you'll actually get *worse* mileage using them at highway speeds. Sometimes I'll leave it in "7th," though, just for the near-constant RPM effect that you'd have with a manual. I say "near constant," because even in a fixed ratio with the paddles, you'll still get a slight RPM fluctuation.
How can a Fit driver make the most out of the CVT, sport mode and the paddle shifters? My concern is highway performance.
This question is pretty much answered above, but I'd add that if you're highway cruising at speed and want to quickly bump to a ratio with higher engine RPM (such as to pass a vehicle), just bump your paddle down once or twice. All you're doing is eliminating the very short delay you'd have by just stomping the throttle and waiting on the CVT to automatically change ratios. Otherwise, for best fuel economy, simply leave it in D and drive the speed limit (or practice some mild hypermiling techniques).
In town, it can be fun to use the paddles in S for a bit, but it becomes more of a chore than it's worth if you're in heavy bumper-to-bumper traffic. I have the most fun with S mode paddle shifting when I'm on a nice twisty road, or running an autocross. For cruising or heavy traffic, let the CVT do the work.
Final thoughts on the CVT: All of my daily drivers over the years (going back to my 1971 Vega from high school days) have been manuals, so my Fit was my first DD automatic (and first CVT purchase) ever (my wife's cars have always been automatics). I've driven one other CVT (Nissan Versa), and the Fit's works *far* better with much less of the "rubber band" effect everyone talks about. The Honda unit is very flexible and can come "in the neighborhood" close to simulating the sound and feel of a manual with the paddles in S mode with some careful throttle work.
That said, it still doesn't have the direct engagedness of a manual, which can take away somewhat from the pleasure of driving when you're on a challenging road or track. The best use case for the CVT is if you're doing a lot of highway cruising or heavy traffic driving – it shines there.
For what it's worth, the four-door sedan that's replacing my Fit will have a manual transmission – along with a 415 HP LS3 engine and rear wheel drive…
es
Old 03-26-2017 | 08:11 PM
Action Jackson's Avatar
It would be nicer if Honda made this with 'five' instead of 'seven' simulated 'gears', as I find it a bit harder to remember which 'gear' I'm in, like my previous manual cars. In the latter's case, I would know which gear I was in just by feeling the position of the shifter.
Old 03-27-2017 | 11:12 AM
Uncle Gary's Avatar
Or maybe we wanted a fun, sporty, stick shift car that we could actually carry something in (like a big screen TV or a Marshall head, a 4X12 speaker cabinet and a couple of electric guitars). Not everybody can afford (or wants) three or four different cars for different purposes. Some of us like to keep life simpler than that.
Old 03-27-2017 | 11:28 AM
fitchet's Avatar
Originally Posted by Fuelish
Have never driven a CVT equipped vehicle that felt "good" ....I'd take a regular old slushbox over a CVT anyday....but, of course, my LX is a manual....in my book, any car with a manual is more engaging to drive than the same car with whatever form of automatic trans.....but that's just me
That's why I say to each their own.
I guess I'm to the "Automatic Transmission" stage of my life. Even though I love manual transmissions.
My Opinion, in comparison to an regular automatic transmission, I like the CVT, if only for the improved fuel efficiency. The driving feel seems pretty comparable "Automatic" to "CVT". Arguably with no shift points...smoother.
But I'm not trashing either manual transmissions or your standard automatic. Just saying, the characterization of CVT as un-fun to drive is not fair.
I do agree with you about manual transmissions. More engaging...fun to drive. But...
Guess I'm getting to the let's just shift it into drive and putt down to Wal-Mart age....
At some point you start to enjoy...less engaging...
Old 03-28-2017 | 02:54 PM
Get off my Lawn ya zipper snapper!
Im 55 and its all about the drive. My fit is the only car out of 4 without a manual and the only reason I originally bought the fit was for my daughters to learn to drive in without fighting the clutch. Its headed off to college with one of them soon..
Old 03-29-2017 | 02:42 PM
TaubBaer's Avatar
Originally Posted by cmchan
Forgive me if these questions sound stupid. My most recent car is from 1998 so I'm not up to date with all these new technologies and such, lol.
I don't think it will cause the higher maintenance costs.
Sport mode gives you higher RPM. Yes, you can shift to sport mode at any speed.
I tend to use paddle shifters when braking down or going downhills. It WILL NOT let you change the "gears" when not in the range.
I rarely use sport mode since I am not doing race track. I still shift down (in non-sport mode) when I need to slow down during the downhills and traffics to save brake pads.
Here you go with my replies.
Old 04-01-2017 | 11:18 AM
fitchet's Avatar
Nice Parent.
True story, but my Dad had me learn on a manual. By choice.
His logic being, once I learned how to "shift"...then driving an automatic would be....well...automatic.
BUT...
He had me learn on a manual transmission where he had replaced the clutch. And it was the trickiest, hair pin, reactionary clutch I have EVER driven.
Especially for a new driver, it was a nightmare to try to use.
My learning was very frustrating. Because I had nothing to compare it to.
Later, I drove other manual transmissions and they seemed SO EASY.
Only in retrospect did my Dad admit he knew the clutch on the vehicle I was trying to learn on was "difficult".
Oh well.
Once I learned...every other manual transmission seemed so easy to use.
Thanks Dad...well sort of...
  #32
Old 04-01-2017 | 01:15 PM
Buck Fitty's Avatar
Or lower. Or the same.
  #33
Old 07-02-2024 | 10:40 AM
Codx323's Avatar
Red face 2009 Honda airwave GJ1 L15A I-VTEC
Hi Fam so I have a 2009 Honda airwave GJ1 combined with CVT and the infamous L15A I-VTEC
SPECS TO DATE
Engine Health: 85-88% (intermittent tapping/knocking + completely Silences when in R,D,S,L)
Transmission Health: 70-85% (intermittent delayed take off response + when cold or in sport no delayed take off at all)
Current ODO ( Millage / Kilometers ) : 159,582 KM or 110,000 /130,000 Miles { KM are exact off the ODO Meter / Miles im just guessing }
Current DYNO Roller Numbers: 127.59 HP 116.39 lb·ft
Current Engine Modifications:
1. Cold air intake system
2. Skunk2 Intake Manifold
3. Piggyback APEXI VAFC 2 ------------------------- Has been Road Tuned By Myself + Checked and Finalized on Dyno By Official Dyno Tech
5. 2.5" Exhaust Resonator and Cat
6. (No Brand) Oil Press + Volt and Amp + Vacuum Gauges
^Cheapy's^
???I want to know if I can make my CVT Switch to 7 speed, I've worked with a lot of thing on this car that apparently weren't in this model.
is it possible that if I swap out my current steering wheel that has no connection or the 7speed / stereo buttons, can I put in a steering wheel that is fitted with this equipment = (Stereo / 7speed) buttons and it connect to the transmission is it possible to just put it on and it magically work like everything else I've done to her???
I already have put in spotlights that weren't there (no button mounted + swapped front bumper for one with mounts for spotlights) However the wiring for the button and lights was already in the car
As goes for Stability/Traction Control buttons + JDM VTEC Lights (the wiring was there for the buttons and VTEC Lights too)
its seeming to be abit of a rare little Nugget I have on my hands and I'm really enjoying making it a Sleeper / Entertaining Commuter car
(((P.S. please don't hate me because I'm in the wrong forum, I've looked all over the internet and this is the closest place I could find to the information I need, Any help is greatly appreciated yes I'm new to the online Honda forum scene but I've been a Honda fan boy for a long time)))
TRDYaris
06-05-2015 02:32 PM
trashercan
06-28-2014 07:24 PM
ak_honda
06-16-2014 09:17 PM
orta.daniel
04-27-2009 01:34 AM
postman
01-26-2006 08:19 AM
Quick Reply: Somebody Explain to me: CVT, Sport Mode, Paddle Shifters
