2013 v. 2015 - rear cargo space
Old 05-22-2014 | 05:04 PM
cmchan's Avatar
interesting gif!
It seems like the 2015 fit would have more cargo space, judging from the comparisons.
  #42
Old 05-22-2014 | 05:38 PM
SR45's Avatar
[IMG][/IMG]
Originally Posted by cmchan
interesting gif!
Fit length is about an inch shorter than the 2013 and about an inch or so wider. Look at the spec's. The photo shown is not accurate
By the numbers by Bradley Hasemeyer
http://www.bing.com/videos/search?q=...3C06781A276255
  #43
Old 05-22-2014 | 05:46 PM
Emirii's Avatar
Are you comparing american Fit version? It's an inch shorter than the gif is accurate, if you can see about 5 inches are taken off of the nose and added a few inches to the rear. It's still a bit hard to visualize. They cut off the front to make a bit more room in the back.
The first gif i made first was the Japanese versions, which noses are the same, this one is not accurate most likely. The images were not consistent.
It looks like they shrunk the nose, made wheel base an inch longer, added a bit more to the back.
  #44
Old 05-22-2014 | 05:50 PM
SR45's Avatar
Yes, USA model. Check out the video I just linked to on " By the numbers"
YouTube with Honda blogger Bradley Hasemeyer - Bing Videos
  #45
Old 05-22-2014 | 06:21 PM
TCroly's Avatar
interesting gif!
True, until you factor in that the rear seat moved back by 4.5"
  #46
Old 05-22-2014 | 06:23 PM
Emirii's Avatar
Yeah, everything got shifted back. Can't find any good "cross section" renders to compare by to see the inside difference. So as far as seats up storage it most definitely got cut. The gif was mainly to show how the body has changed.
  #47
Old 05-22-2014 | 08:18 PM
tmfit's Avatar
It is a cool gif Emirii, great way to see the difference! It would be tough to find 2 photos that that would match up in this world of photoshopping. Thanks for taking the time to do it
  #48
Old 05-22-2014 | 10:46 PM
fujisawa's Avatar
Originally Posted by GeorgeL
Well, Honda did hang a big snout on the earlier Fit for the US market. Perhaps they engineered it to be more compact for the new "world market" version.
Yes - they did add a larger snout on the 2nd gen US Fit. The short-nose version wasn't designed for US crash standards, so they had to add a bit.
The new one looks like it's got both more wheelbase and more rear crash-absorbing metal. I would guess the lower cargo room is from the frame or suspension encroaching on the trunk a tiny bit more, or it's just a measurement difference -- they probably aren't the same person doing the calculations, not after 10 years
Anyway, the difference is not large. The new Fit is more elegantly proportioned, slightly more efficient and fast, slightly more boring, and has about the same space inside. I don't think I'd have a lot more to add
  #49
Old 07-31-2014 | 10:22 PM
Splash's Avatar
Floor height...
Originally Posted by Japan Tragic
Id need to get the measuring tape out, the 'magic' seats look nearly identical in operation to the GE with how they fold down etc. Its possible they sit higher but I dont think so.
from the look of all the measurements so far they are almost the same with the GK being slightly ahead. Cargo space wise I dont think there is enough of a difference either way for the amount of attention this forum seems to be making about it.
will chase it up next time I get to take the fit out.
The bottom of the back seat looks much thicker in the new fit. Also there is a real spare tire under the floor in the rear of the cargo area. That probably makes the floor higher in the new fit and accounts for some of the loss in cargo space.
  #50
Old 07-31-2014 | 10:24 PM
Japan Tragic's Avatar
you guys get a full spare tire? there is no spare tyre in the JDM version, its just a pump and puncture repair spray.
  #51
Old 08-01-2014 | 12:31 AM
CrystalFiveMT's Avatar
After having my 09 Fit for 6 years, and scrutinizing the new Fit's interior, I don't even need to measure to see that the new Fit has easily much LESS space than the GE in terms of headroom, trunk space and cargo space with rear seats down. The floor is visibly much higher and ceiling lower. Trunk space is less deep, with the floor much higher and the wheel wells intrude more. Too bad.
  #52
Old 08-01-2014 | 12:39 AM
all measurements are saying otherwise which is strange.
  #53
Old 08-01-2014 | 04:45 AM
fit2tri's Avatar
and yet, I can fit 2 bikes (48 cm and 56 cm, standing up, front wheels off) in the back with only part of the back seat folded down, leaving room for gear in the back end and a 3rd passenger in the back seat. Or the two bikes with the whole back seat folded down plus room for 2 suitcases, 2 large gear bags, a medium ice chest...
Don't have an older Fit to compare to, but my 2015 is pretty darn roomy!
  #54
Old 08-01-2014 | 05:06 AM
TCroly's Avatar
I did make some measurement comparisons between the GE and GK cargo areas. The size of the floor is almost identical, both seats up or seats down. I confirmed, as someone else had already posted, that the cargo mat from the GE fits almost perfectly behind the rear seat in the GK.
It appeared that all of the difference between the two cars is from the load floor being approximately 2" higher in the GK, and the sunroof causes a loss of about 1" in overhead space. I measured 51" from the floor of the back seat to the roofliner in the GE and in the GK was 48". This measurement was 43" in the GK from the center hump to the roofliner and 46" in the GE. The height of the cargo area seats down to roofliner was 36" in the GK and 39" in the GE.
So overall the cargo area of the new car is 3" less tall throughout. So if you stack stuff all the way from the floor to the roof, you might not be able to fit as much. But from a more practical sense. The GK rear hatch opening is actually 2" taller(33" vs 31") than the hatch opening of the GE. So if you are trying to carry a tall box or item, it will more easily fit thru the hatch on the new car. Overall both cars are still in a class of their own for cargo space in the subcompact or compact class.
  #55
Old 10-14-2014 | 08:18 AM
morgantruce's Avatar
I used to brag that my Subaru's could carry a couple of 8-foot pieces of lumber --- resting them on the dashboard just short of the windshield---and then hoping to not have to hit the brakes on the way home.
My new Fit can carry a large amount of 8-foot material and the ends are in the passenger footwell -- much safer!
  #56
Old 10-14-2014 | 11:15 AM
Canoehead's Avatar
Originally Posted by ydnality
Thanks for this! I've been comparing the Fit to the Mitsubishi Mirage for some time, and on paper the Mirage is almost as big. In reality (I've driven and been in both cars) the Mirage is noticeably smaller.
This is my synopsis of the relative efficiency/economy of both cars: Efficiency/Economy comparisons to Honda Fit - MirageForum.com
I included your link here:
Cargo Volume? - MirageForum.com
  #57
Old 10-14-2014 | 12:17 PM
kenji815's Avatar
2015 has the same chasis as previous model
  #58
Old 10-14-2014 | 06:05 PM
GeorgeL's Avatar
Well, we get a doughnut, not a full size spare. In the western US it is possible to be hours away from a tow truck so a real spare is a necessity. Some manufacturers like Kia are trying to foist the sealant kits on us and then sell a spare wheel/tire/jack at an inflated price but Honda thankfully provides a doughnut spare.
My Scion xB also has a spare tire where the Japanese bB did not. It was amusing to find out that they had to store the jack under the driver's seat since the xB was not really designed to be anything other than a JDM car.
  #59
Old 10-14-2014 | 06:22 PM
sooznd's Avatar
I am happy I can fit my 2 kayaks inside my 2010 GE- one is 8' 3 " the other is 7 ' 10".
It would be even better if the rear seat configuration was the opposite 60/40 configuration- but it works.
  #60
Old 10-15-2014 | 10:34 AM
PaleMelanesian's Avatar
YES! If you have to carry something diagonally, you have to fold down both rear seats. If the 60/40 were swapped, you could leave the 40 half in place behind the driver and only fold the passenger side.
Quick Reply: 2013 v. 2015 - rear cargo space
