Love to hate the new Fit/Jazz
#41
Tailgate fine I think. Bumper not too bad, left an imprint of her license plate frame on the plastic, and ripped off the lower "sport trim" valance. The body shop will examine underneath the plastic this Thursday. Older sedan, so it was bumper to bumper.
#42
Hi JT, do you happen to know if the suspension is the same as the GE8? Would like to transfer my coilovers to the gk once I get it.
#43
I know its a very similar setup but does have different part #s from GE to GK from Tein so I fear while similar it wont be an item you can swap across
#44
Ahh really hoping it was interchangeable like GD AND GE. Thank you so much. You saved me so much research. Hahaha. Now have to sell my APEX-I coilovers
#46
much easier to hold on to the suspension and then sell once you know for sure.
#47
Thank you mike I'll give it a shot. That's true thou.!
#48
That's JT, I'll give it a shot before I sell them.
#49
Here's the permanent OFF switch for the START/STOP feature you were wishing for:
NOBLESSE `ƒmƒuƒŒƒbƒZ` ...it's in with the FIT3 parts!
#50
NOBLESSE `mubZ` ...it's in with the FIT3 parts!
awesome! thanks for the link.
Fitted a Js racing decat pipe about a year ago and the ECU has hated it setting off a bunch of warnings, 1 of them being disabling the idle stop! Haha
#52
https://www.jsracing.co.jp/js2/index...=41&xSHASHU=39
#53
only Js racing that I know of. the L15B has an intergrated exhaust manifold (its part of the head) so the front / dump pipe looks almost like a turbo dump pipe... one thing is that you have to block off the EGR and that upsets the ECU with lots of errors and warning lights.
great to see a GK owner in Japan
is yours a GK5 aka Fit RS ?
#54
yes mine is an RS, although only difference for RS is slightly stiffer suspension (I swapped to Tein coil overs anyway) some trim/options and orange color is only available for RS. performance wise is same as other 1.5 litre Fits.
I use it as the daily and like all the generations of Fit, economy/cargo/reliability are all good so it works very well for what I bought it for.
On the highway ~135hp is not crazy fast but will cruise at 160kph easily.
#55
I own a GD3 and I see the specs of the Fit RS it looks damn temping , DOHC , 6 speed and VSA and the blings
I look at Honda Japan I thought is available in some colours too ?
I did test drive a Jazz RS from dealer but somehow the ride feels floaty thou
Is the Fit RS affected by the idle start stop that occur in the Vezel ?
#56
I see thanks for the info
RS comes in standard colors also, but the orange is for RS only.
I found the standard springs quite harsh but car was too high which is why I went tein coil overs (was just to lower it)
Fit RS has the same idle stop which I found annoying.
#57
I think from 1.3 to 1.5 the power increase is quite good.
I agree the stock spring make it high and makes the car floaty when I test drive it
Has Honda Japan initate a recall already ?
Any problem so far ?
#58
there was a recall for ignition insulation issue. but for the RS that was all.
the hybrid DCT transmission has had many issues and lots of recalls.
#59
Alrite thanks , is in consideration whether to go with my trusty GD3 or looking at the Fit RS
Thanks
Kmac66
07-29-2016 09:33 PM
