Oil Extractor
Oil Extractor
I was all set to order an oil extractor, and then I remembered the oil filter. Looking at the engine just now, I realize there's no way to replace the filter from up top. That's too bad. Maybe I'll look into getting a remote adapter. : )
It would be so nice to avoid driving the car onto the ramps, crawling underneath, and removing the splash pan before even starting to drain the oil. I've seen several people use extractors online, and nothing, or close to nothing, remains in the pan when they finish sucking the oil out.
It's been used for everything from engine oil, transmission fluid to Power steering fluid, brake fluid, coolant etc.
Considering the time and money I've saved by using one of these, it's easily paid for itself MANY times over.
It's honestly one of the best tool investments I've ever made.
The only downside is the filter on the FIT (also had the same issue on my Lexus and Focus), but in the grand scheme of things, it's not a big deal.
Especially since Honda recommends changing the oil filter every second OCI per P 357 of the owner manual
It's not that it's difficult. With an extractor, I would avoid removing that piece and using the ramps - and getting under the car. I've replaced those plastic screws on the shield with metal quick-disconnects.
I've been using the same extractor for about 8 years and 4 very different cars (e30 BMW 325is, Lexus IS 350, 07 Focus SES, and the 2016 FIT).
I've never liked the idea of skipping the filter change.
Mister Coffee
24
03-17-2024 12:54 PM
CasualFitOwner
15
04-29-2013 10:07 AM
Odie
13
06-25-2012 06:31 PM
