Your Mods list.
Your Mods list.
I have so far.
Acuity engine bay cable bushing, pedal spacer,shifter base solid bushing and shifter collar and knob.
Ultra racing 19mm rear sway bar.
Next to come is hasport solid mount.
My 2018 GK5 Sport:
ENGINE/TRANS
APEXi SMART Accel Throttle Controller
Spoon Air Cleaner
Spoon Oil Cap
Spoon Radiator Cap
Spoon Clutch Line
Spoon Exhaust B-Pipe
Spoon Axle Back
Spoon AirBox Decal
Acuity Transmission Shifter Bushings
EXTERIOR/LIGHTING/WIPERS
Mugen Ventilated Visor
Mugen License Plate Bolts
Bosch Front Right Wiper
Bosch Front Left Wiper
Bosch Rear Wiper
Phillips Reverse Lamp Bulb
Philips License Plate Bulb
Philips Parking Lamp Bulb
Philips Side Marker Bulb
WHEELS/TIRES/BRAKES
Goodridge Brake Lines
Mugen Brake Rotors (Front)
Endless MX72 Plus Pads (Front)
Nankang CR-1 (205/50/15) (Track)
Yokohama Advan Fleva V701 (195/55/15) (Daily)
Mugen Lug Nuts
Wedsport TC105N 15x6.5 +42
SUSPENSION
Hardrace Adjustable Sway Bar Links
Koni Streets Struts (Orange)
Tanabe DF210 Lowering Springs
SPC Camber Bolts 81260
Zero Fighter Strut Bar
Zero Fighter Rear Pillar Bar
Zero Fighter Rear Sway Bar
INTERIOR
Spoon Shift Knob (6-MT)
Spoon Rear Veiw Mirror
Mugen Umbrella
Treefrog Air Freshener
Honda OEM Cabin Air Filter
Honda OEM Mood Dome Light
Honda OEM Mood Dome Harness
Honda OEM Rear Seat Back Protector
Honda OEM Rear Cargo Tray
Honda OEM Sports Pedal Set
Honda OEM Trash Can
Honda OEM First Aid Kit
Honda OEM (UK) Seat Storage Bag
JDMTOY LED Cargo Light
I have the links for everything if interested.
ENGINE/TRANS
Spoon Air Cleaner
Spoon Oil Cap
Spoon Radiator Cap
Spoon Clutch Line
Spoon Axle Back
Spoon AirBox Decal
Bosch Rear Wiper
WHEELS/TIRES/BRAKES
Mugen Lug Nuts
SUSPENSION
INTERIOR
Mugen Umbrella
Honda OEM Trash Can
A Honda OEM trash can? That's got to be the weirdest car thing I've heard in a while. Not bad, not poking fun or anything, but never occurred to me that such a thing would exist.
On my 2015 LX-
Lowered on Megan springs with Koni Orange shocks (from a GE, works fine)
Enkei RPF1 wheels, 16x7, the 15" are lighter but you lose performance tire options
Camber bolts because they rubbed after lowering
Progress rear sway (best single mod for this car)
Fastbrakes rear disc conversion (don't get HP+ pads, they squeal like crazy)
Hasport solid rear mount (thinking this was a waste of money)
RV6 catless downpipe (great performance, horrible rasp, get the catted version)
Magnaflow muffler welded on by local shop to remove the rasp
Homemade plywood trunk floor/hatch, got rid of the foam tray and keep a rifle in there instead.
Would be getting a gas pedal relocation bracket but probably selling the car soon.
On my 2015 LX-
My 2018 GK5 Sport:
ENGINE/TRANS
Spoon Air Cleaner
Spoon Oil Cap
Spoon Radiator Cap
Spoon Clutch Line
Spoon Axle Back
Spoon AirBox Decal
Bosch Rear Wiper
WHEELS/TIRES/BRAKES
Mugen Lug Nuts
SUSPENSION
INTERIOR
Mugen Umbrella
Honda OEM Trash Can
ENGINE/TRANS
Spoon Air Cleaner
Spoon Oil Cap
Spoon Radiator Cap
Spoon Clutch Line
Spoon Axle Back
Spoon AirBox Decal
Bosch Rear Wiper
WHEELS/TIRES/BRAKES
Mugen Lug Nuts
SUSPENSION
INTERIOR
Mugen Umbrella
Honda OEM Trash Can
Pretty much any lowering springs will be stiff enough that they won't be a good match for the factory shock damping rates. The only shocks I've seen anyone use here are the Koni Orange, unless they go for HFP shocks to match HFP springs, or full coilovers.
If I had it to do over, I'd give coilovers a serious look. Not for the corner weighting, though that's a good thing, but for what sounds like better damping from more expensive shocks. The Konis with my spring rate feel like they're a decent match, but they're a little harsh. The car can become unsettled over rough pavement, like a damping rod fork on a motorcycle compared to a cartridge setup. Some folks here with coilovers report a more plush ride over broken and potholed surfaces while remaining stiff enough to control a stiffer spring.
Mods so far:
-Sumole air cooler
-Drop in k&n air filter
-RV6 catted header/collector
-2¼" "B" pipe (will do "mandrel bend" if it works)
-Tanabe Medallion axle back
-CRZ BuddyClub short Shifter
-Acuity shifter cable bushings
-Acuity accel. pedal reloc. bracket
-KTuner V2
Intake mods...
-Covered up all sound deadening holes on oem airbox to force all air through intake to the throttle body
-k&n drop in filter
Fun part...
Got ahold a used but nice condition CR-V throttle body and since it WON'T fit the oem intake manifold a friend of mine and I fabricated an aluminum spacer to adapt it...
-I also disassembled the oem elbow from the airbox and used a 63mm x 70mm 90 degree elbow since that is the "bottleneck" of the tiny intake....
SIDE NOTE:
i haven't been able to dyno it, but... the "butt dyno" feels pretty good after the mods
-Sumole air cooler
-KTuner V2
Intake mods...
-k&n drop in filter
Fun part...
SIDE NOTE:
Mine just looked like rubber without the text, wonder why they were different. Initially when I installed my Hasport mount my car sounded like it was about to rattle itself to pieces, but after a few months it settle down quite nicely. I do appreciate not feel okie that small “thunk” from the engine moving back and forth.
which durometer did you settle on?
I think you’ll be fine. It’ll take a bit to break in so you’ll hear and feel some NVH, but it will eventually settle down so don’t worry!
Good stuff mate. Acuity products have been, meh! The ultra racing sway bar and continental c6 195 55 sitting on R15 rims have been the real good worth it mods. Learning these as i go along. lol. Might go with the heavier skunk 2 gear knob as the acuity one is just not heavy enough for that shift feel i am after.
