Fit 2015, turning on headlights no longer dim infotainment and dashboard lights
I have a 2015 Fit that's been driven around 76K miles. My car just randomly starting no longer dimming the interior dash lights and infotainment automatically when I turn the headlights on.. I have to manually click the brightness button on the infotainment and change it to dark mode every time I drive during the evening. That being said, the volume lights and the dash LCD backlight still doesnt dim since there's no way of manually controlling those..
Anybody had this issue before or know if its a setting that randomly changed or something? I noticed it after an oil change I did at a garage but they said they didn't do anything except reset the oil counter..
The only "glitch" my Fit seems to sometimes manifest is I have found intermittently I will put it in reverse during the day, and the back-up camera will come up with the darker lighting settings and I have to press the button and TELL it it's still daytime, or the display will be too dark.
Doesn't happen enough for me to define it as a real problem, and even when it does happen....it's just a button press fix.
I believe there is an ambient sensor that determines the dash brightness. When I have the headlights on during early evening, the dash is dim then suddenly it brightens up when the outside got darker. You will also notice that dash brightness knob does not function when the ambient lighting is bright, ie, you cannot change the console gauge brightness at that time.
Not when your headlights are on during bright ambient light. Rotate the knob that controls the brightness of the gauges. When you have your headlights on during daylight you will find that the knob does not work to increase or decrease the brightness of the gauges. Honda knows best.
