FIT RS Earth Dreams Motor
I was reading this morning about engines, I was curious if the 2016 civic turbo motor was direct injection like the fit and the difference in the compression ratio when I found the 1.5 earthdream motor specs.....
L15B EARTH DREAMS
Found in 2015-2016 3rd generation Honda Fit in North American Market
If that info is correct 208 hp at the flywheel in the light body fit would be pretty quick? I would love to know if that is true specs and what is the difference.
L15B EARTH DREAMS
- Debuted in:
- Honda Fit RS
- DOHC 16 valve I-DDSi (Intelligent-Direct-inject-Dual Sequential Ignition) Second Generation Earth Dreams DSI
- Displacement: 1,496 cc
- Bore x Stroke: 73.0 mm × 89.4 mm (2.87 in × 3.52 in)
- Compression Ratio: 11.5 : 1
- Power: 155 kW (211 PS; 208 hp) / 4,200 rpm
- Torque: 355 N·m (262 lb·ft) / 2,600 rpm (GK5 Fit)
- Carbon Dioxide (g/km): 129
- Honda Fit (Thailand, Japan)
- Honda Vezel (Thailand, Japan)
- DOHC 16 valve i-VTEC
- Bore x Stroke: 73.0 mm (2.9 in) × 89.4 mm
- Power: 97 kW (132 PS; 130 hp) / 6,600 rpm
- Torque: 156 N·m (115 lb·ft) / 4,600 rpm
- Honda Vezel
- Honda Fit Hybrid 2013+
262lb-ft of torque? At 2600rpm and it's not a turbo? Nah man..that can't be right.
Look at this link ---> Japan Fits
Plenty of fits to look through and at their specs.
I can't tell if this is real Honda video!?!?
https://www.youtube.com/watch?v=HNJINGdsq9A
Still thats a lot of power for a FIT...
Trooper1985
10-05-2023 05:05 AM
Fit Hybrid RS 2012
07-28-2015 09:20 PM
