signal rpm from ecu
signal rpm from ecu
somebody...please help me... i want install my tachometer autometer cobalt on my GK5 but i dont know how to install and connect cable signal rpm from ecu... everyone please if you have wiring ecu gk5 please share.... or which cable from ecu to signal rpm... thankyou
If the engine uses 4 individual ignition coils instead of the traditional dizzy (distributor) I do not think there is an easy way to connect a typical accessory tach.
(I've not noticed a 'tach test' connector in the engine compartment since they stopped using distributors.)
I read this on the description of a tach on their website:
Each ignition coil has a 3 wire connector, 2 of the wire colors are common to all four coils (power and ground) and there should be one remaining wire in each connector that is the 'trigger' to turn the coil on and off, the color of that wire is different for each coil.
- Compatible with 1 - 4 pulse ignition signals (2-8 cylinder engines) with points, electronic, and most 12V high-performance racing ignitions.
[QUOTE=ezone;1330368]If the engine uses 4 individual ignition coils instead of the traditional dizzy (distributor) I do not think there is an easy way to connect a typical accessory tach.
Can you help please!!!
[QUOTE=Ladydriver;1373697]
I have a 2013 Honda Fit. Coil is fine. Injector is fine but spark plug needed to be replaced. It had been miss firing. Codes are telling me there is no ground to cylinder 4, therefore no gas going in. three dealers and no one has heard of this problem. I would like the fuel injector wire harness diagram, and suggestions please ! Thank you
I have a 2013 Honda Fit and no fuel is ge
Rpm signal
Any update sir if u did install tachometer[ in your gk5...thnks
QUOTE=Bayu Tuk Windriyo;1330367]somebody...please help me... i want install my tachometer autometer cobalt on my GK5 but i dont know how to install and connect cable signal rpm from ecu... everyone please if you have wiring ecu gk5 please share.... or which cable from ecu to signal rpm... thankyou[/QUOTE]
maxswisher
05-06-2016 01:36 PM
guailifit
36
09-03-2014 04:20 AM
lakia5524
04-21-2014 10:59 AM
Lyon[Nightroad]
06-21-2010 04:55 AM
