Hasport K series Mounts Gk5 ... Swap time
We will have these on our website soon but wanted to get you guys thinking.
This mount kit came from our Gk5 which was test fitted with the K24z
These motors are very affordable and with turbos make an easy 400whp.
We have been doing 9th gen Civic stuff from day one and know them better than anyone out there, time to get your Gk5 some power.... Stay Tuned
Acuity shifter will be released soon will have options to switch it to a CRZ also... expect pricing to be around $440 area
Pretty straight forward swap..
Engine $700
Trans $1000
DP which will need fabbed $250
Mounts $440
Axles $300
Harness and computer $400
Intake manifold and intake $600
Ktuner $449
Give you guys an idea... tuned you are looking around 210whp with these K24z motors... We have tons of turbo guys running 400whp bolt on
Engine $700
Trans $1000
Mounts $440
Axles $300
Ktuner $449
I remember reading a thread in a CRZ forum a little while back, guy ran the math and estimated a 40-60 pound gain
Are you guys going to have a kit available with all the non factory parts? I'm assuming the axles won't be a simple swap for a TSX part, and it wouldn't surprise me if the wiring harness needed to be adapted somehow. At the very least, you mention the need to fab a downpipe.
I've never really looked into a swap before, so I could be completely wrong. Still, the less I have to look around for local shops to finish the job, the more likely I am to buy the mounts.
your car looks too good, this would be a bad candidate for a swap
looks like you'll have to stock with your current engine, and remain as is
Is it possible to use the I take manifold off another k series like a k20? Also for the harness will you guys be making a harness kit or can you use a full harness and ecu from the donor car? (Like a crv or civic si)
axion_industries
214
04-03-2023 11:43 AM
axion_industries
62
09-20-2018 08:07 PM
