Tire size
Old 03-19-2015 | 12:22 AM
Payo's Avatar
Tire size
Would 215 45 16 fit on my stock wheel 2010 Honda Fit sport 16x6 wheels
Thanks.
Old 03-19-2015 | 12:56 AM
c3kay's Avatar
Yes. Increases overall width of the tyre by 30mm. Which is fine. But your speedo will be slower than your actual speed because the circumference of the wheel is smaller. The speedos on stock wheels tend to read slower anyway, so depending on how much yours is off by stock, you could be up to 4mph slower at 60mph.
Old 03-19-2015 | 01:30 AM
555sexydrive's Avatar
That's asking a bit much for a 6" wide wheel. Almost every tire manufacturer recommends, at a minimum, a 7" wheel width for a 215/45. Not saying you are not going to get a seal on the bead, but is there a particular reason you want to run that wide of a tire on the stock wheel?
Old 03-20-2015 | 01:43 AM
specboy's Avatar
205 is typically the widest you want to run on the stock wheels. Like was also mentioned, your speedo (and odo) are going to be about 1.6% on the high side. (you'll be reading faster than you are actually traveling - and your car will hit a mile on the odometer about 75' before you actually go a mile.
Not that this likely impacts you but if someone did this on a new car, their 100,000 mile power train warranty would expire after the vehicle had only traveled 98,600 miles (however the odometer would say 100,000 miles.)
Like 555 asked, is there a specific reason for this size? 205/50 works really nicely on the stock wheels. That's what I run.
~SB
Old 03-20-2015 | 04:35 PM
Wanderer.'s Avatar
I would not put 215's on 6" width wheels unless they were free and I was broke and needed tires. 205 is even asking a bit much for 6".
Old 07-12-2019 | 12:55 PM
silverrose12's Avatar
btw, anyone has photos of any 17inchs on thier vehicle?
Old 07-12-2019 | 01:50 PM
Goobers's Avatar
17x7 Enkei PF01 using 205/45/17 Continental ExtremeContact DWS 06
Why are you necro'ing this thread and then going off topic?
edit: oops, mistyped the aspect ratio of the tire. 145 would be freaky.
Old 07-12-2019 | 02:49 PM
Fit2Bsquare$'s Avatar
They would work but it would be awfully close due to the width.
Old 07-12-2019 | 04:16 PM
ohh thank you it looks pretty good ! 17inch is not bad.. the only problem would be that i will have to change my OEM rim =(
and as for necroing; i was just searching for tire and came cross here for some reason haahaa
Old 07-12-2019 | 04:17 PM
i am looking around for 205/50 17inch insce they cost pretty much similar to 185/55 16inch
Old 07-12-2019 | 05:09 PM
evilchargerfan's Avatar
i love a bump from the dead. shows the guy probably went out and used the "search" function =)
Old 07-14-2019 | 05:18 PM
Goobers's Avatar
If you're going to 17" wheels and want to keep the odo "correct," then you'll want 205/45/17 tires, not 205/50/17.
205/50/17 will make the overall diameter an inch bigger, and as far as your odometer, it means you'll be going faster than it indicates.
I think the tires you want are 205/50/16, those will fit OEM wheels.
Old 07-15-2019 | 09:54 AM
i see i see...
i should stick with 16 inch XD
may be i'll go 205/50/16 like u said.. thank you for your input
Old 07-15-2019 | 12:51 PM
Goobers's Avatar
Oops, rather than odo, it's supposed to be speedo.
blvsphemy
01-09-2020 01:13 AM
Previc93
03-06-2013 02:44 AM
annunC8
10-14-2010 12:46 PM
Scaldy
12-25-2008 12:00 AM
avosfit
06-19-2006 09:44 AM
