OZ Alleggerita HLT
OZ Alleggerita HLT
![](http://img85.imageshack.us/img85/8189/ozalleggeritahltblue.jpg)
I've been trying to find a set of blue wheels, and most don't make them with a +45 offset (tons in +40 offset). But I found these from OZ. Here are the specs:
HOle Pattern: 4x100
Offset: +44
Weight: 6.29kg
They do have a 16x7, but it only comes in a +37 offset
![Frown](https://www.fitfreak.net/forums/images/smilies/frown.gif)
Now the other problem I have is buying them! Tirerack has them, but they don't even list it for the Fit. And I have no idea where else to buy them.
16x7 +37 will fit with no rubbing. don't listen to them. honestly the person you spoke to was looking at a computer with preset configurations already and prolly dont know jack shit about what those numbers are. they are doing this so you can't go after them if something were to happen.
^ On a GD that wouldn't be too much of a problem, but a GE is a different story.
Give this threads a read. Going by your previous posts and avatar you own a GE8 and according to the thread below. You would have to have the fenders rolled to run the 16x7 +37s and you can run the 17x7 +44 without rubbing as long as you don't lower, if you do lower, you may have to roll the fenders, add camber, trim the rear bumper, tuck the fender liners, or a combination of these to make it work.
https://www.fitfreak.net/forums/2nd-...ng-thread.html
https://www.fitfreak.net/forums/2nd-...s-caution.html
mikeGe82012
05-28-2017 12:11 AM
linnboi
07-20-2012 12:43 AM
