searched and searched: 16x7 +40 ?
Old 12-02-2009, 02:01 PM
thebluepotato's Avatar
Is anyone running a 16x7.0 with a +40mm offset?
If so, are you running a 50 or 45 series tire and are you lowered at all?
I'll keep checking, but nothing much out there in terms of this fitment on a 09 Sport.
Thanks in advance!
Old 12-02-2009, 03:29 PM
redrumm's Avatar
just run the stock sport tires. you should be fine.
are you lowered or stock?
Old 12-04-2009, 11:13 PM
I am not anything at the moment, but would like to go with a set of 16x7 rotas that are +40 on the offset and not sure they will fit on a lowered Fit. Anyone?
Old 04-05-2010, 06:09 PM
j6kwok's Avatar
BUMP
would like to know as well
I'm lowered on Eibach Pro kit and I'm looking at Buddy Club but they only make 16x7 +40 4x100 bolt pattern
Old 04-05-2010, 06:29 PM
JDMxGE8's Avatar
The ideal tire size for 16x7 would be 205/50/16.
Old 04-05-2010, 06:37 PM
j6kwok's Avatar
Thanks for the reply but will it rub running a +40 offset with 205/50/16 or 205/45/16
Old 04-05-2010, 06:57 PM
k20a298ek's Avatar
get rid of the wheels you will rub like crazy. +43 at least.
Old 04-05-2010, 07:01 PM
JDMchris.com's Avatar
I run THIS
you will be fine. I run 16x7 on a 205/45/16. you can run a 205/50 if ir stock height other wise i would go with the 45.
Old 04-05-2010, 07:07 PM
Octrain's Avatar
What's your offset and are you dropped at all? Does it rub at all if you hit a bump? Was looking at the same wheel/tire setup with +43 offset (RPF1's) and 1.2"F 1.0"R drop (Progress springs). Sound pretty solid?
Old 04-05-2010, 07:09 PM
I run THIS
+42 offset no rubbing on bumps, yes I am dropped about 1.8 up front and 1.5 in the rear. Only rubbing comes from extremely hard cornering. You should be fine on that setup ur wanting to run.
Old 04-05-2010, 07:14 PM
j6kwok's Avatar
I want these Buddy Clubs but they're +40
D-UNIT09 is running Enkeis +40 on 205/45/16 and he's lowered on DF210s with no problem was wondering if this is a special case or what
Old 04-05-2010, 07:20 PM
keepitpg's Avatar
i love college
i have a gd and im on 16x7 +40 on 205/45/16's and slammed. i rub on bumps and turns
Old 04-05-2010, 07:35 PM
Octrain's Avatar
Is this the GD in your sig? Mine's a GE; apparently there's a big difference with offsets and drop potential
Old 04-05-2010, 07:48 PM
I run THIS
the Buddy club sf P1? I ran those in 16x7 with +42 offset in that tire size as well with no problems.
Buddy club doesnt make a 16in wheel with a +40 offset
Old 04-05-2010, 08:03 PM
Type 100's Avatar
Tire sizes will be slightly different depending on the chassis.
GD: 205/45R16
GE: 205/50R16
On my GD1, I have 16x7 +45 wheels at stock height and I use 205/45 tires. No rubbing whatsoever.
GEs are okay with the same tread width but the aspect ratio should be a little bigger.
Old 04-05-2010, 09:50 PM
j6kwok's Avatar
that's what I thought too but apparently BC stopped making the +42 in 4x100 their website is wrong my local shop called and confirmed this
Old 04-05-2010, 10:35 PM
Wongawa's Avatar
I have 16x7 +42 and I just changed rims and used the stock tires for now. I'm not lowered yet though.
Old 04-05-2010, 10:37 PM
I run THIS
hmmm... the 2mm wont make a difference anyway.
Old 04-05-2010, 11:43 PM
Sugarphreak's Avatar
Push My Button
2mm always makes a difference
I know this is a GE8 thread, but I had +42 rims on my car and massive rubbing problems... I went to +45 and it all went away!
Also here is a link the the lightweight wheel thread, it details all the rims that come in high offsets and are lighter than the OEM rims:
https://www.fitfreak.net/forums/fit-...el-thread.html
Chris, could you sticky that thread for me. It is a valuable database for anybody looking for rims with high offsets.
Old 04-05-2010, 11:46 PM
I run THIS
werent you on 17s? the +40 on 16s are fine.. I had 16's in +38's with no rubbing.
Quick Reply: searched and searched: 16x7 +40 ?
