Why no aftermarket FRONT sway bars?
I also stepped up to a 205/50/16 tire and it handles so good I can't stop heading to the canyons.
The ride is still comfy enough for the whole family but the body roll is all but gone.I really cannot describe the big difference compared to stock
you need to take a ride in a Fit with Swifts and progress RSB
We auto x our 2012 FS. Only mod is camber bolts and 205's up front running 47# pressure. The fit wont roll unless you do something you shouldn't have. Fit rocks stock. I suppose I need some swift springs.
Why do you need camber bolts?...
I'm with mkane here. Relax, your GE won't roll - not on the street, and not on stock suspension, unless you're extremely clumsy with the brakes mid-corner in the rain...and even then you have ABS as a safety net (I don't).
The fit has 0 front camber stock, and under extreme cornering (like at an autocross or on track), the car will roll a few degrees and that means the front tires roll the same amount and then you are only using the outside edge of the front tire for grip. Adding negative camber leans the top of the front tire toward the center of the car so that the car rolls "onto" the contact patch, and front end grip is hugely increased.
Ingalls sells camber bolts used to do this and it's the biggest performance gain in extreme handling available (with the Progress rear swaybar being the second biggest improvement).
Chris
Chris
Will this work in rally cross on loose surfaces?
A bit of a poser without the skills/ money to really compete I like to try to raise eyebrows by doing one event just before discarding a set of tires. The car is a 2012 base model with a sport rear axle, 16 x7 TR motor sport wheels and 205x55x16 DWS tires... a little bit taller...
Camber bolts just might do the trick. Please speak up if you see a train wreck.
Thank you.
Because it's a strut front and a strut gains not camber under compression, the amount of body roll you have is also how much you wheels are rolling (positive camber)... so I would be it's common to see 3 degrees of roll on the Fit, and that means you are loose quite a bit of the tires grip.... if the tires are good.
If the tires are bald, maybe the outside edge gives you more grip???
Chris
i know this isnt what you are talking about but, all the rear sway bars that i have seen here in canada and usa they are more of a strut bar. they make the rear axle stiffer but they are not a real sway bar. from what i can see they never do connect to the frame of the car, just get screwed in just under the rear springs. is there any rear sway bar that is an actual real rear sway bar for the gd3?
^The Whiteline bar is more what you're looking for:
https://www.fitfreak.net/forums/fit-...-sway-bar.html
#32
Whiteline products do not fit the USDM model Fit....
Its lower down in the above thread:
after going back n forth with whiteline about different issues and getting different hardware to test...
it wont fit USDM.
There isnt enough space between the fuel line and the torsion beam. From their diagram, it looks like the fuel line goes over the torsion beam, whereas the USDM one goes under.
it wont fit USDM.
And I myself bought several of there LCA bushings.... which are designed for a different market car with completley different LCA's.
I would LOVE to have a Whiteline type rear bar on my GD3, but I do not have the time to fabricate one OR safely/class legally re route my fuel return line...
#33
Weird that the fuel line would be different, seems like an odd thing to have a different part for JDM and USDM models. Maybe they ran into a safety issue DOT didn't like... idk?
#34
The lower control arms are COMPLETELY different... therefore maybe even more of the front suspension and lower cradle are too...
#35
I have no problems getting my GE8 to rotate on an autocross course, and even smaller road courses. Sometimes I read through all these suspension threads and think i'm the only one that doesn't have a rear sway bar... and I still don't want one. Is everybody else driving on a full tank of fuel during events?!
#36
I am lost on the fuel comment... What do you run for tire pressures and do you use stock camber?
#38
Wheels are 15x7.5 949racing 6ULs with 225/45/15 Hankook R-S3s.
Can't wait for BFG Rivals
You are correct. The car behaves quite differently depending on fuel load.
Nicotine
19
09-10-2014 01:50 PM
thedeadpoet000
17
09-18-2007 09:52 AM
2008, 25mm, aftermarket, bar, bars, fit, front, ge8, honda, nqsperformance, spoon, sport, suspension, sway, upgrade
