Another Spacer Question...
Old 02-09-2012 | 01:45 AM
SenBlue09's Avatar
I was curious if I needed a hub ring for my 5mm slip on Kic spacers for the rear. I hear they are just slip on and done, but won't the spacer be loose since its 75mm inner diameter, and the GE bore is only 56.1 in diameter? I have a 1 inch drop from Progress sport springs, and upgraded to 205/50/16 tires, if it makes any difference. Any info would be awesome! Thanks
Old 02-09-2012 | 02:06 AM
solbrothers's Avatar
you won't need a hubcentric ring. your wheels aren't even hubcentric.
what is the thickness of your spacers?
Old 02-09-2012 | 09:09 AM
SenBlue09's Avatar
5mm Kyo-Ei Slip On, going on the rear oem sports
Old 02-09-2012 | 10:22 AM
aah you should be okay. just be careful that you have enough stud showing.
Old 02-12-2012 | 01:21 PM
lowered_klass's Avatar
I'll be adding spacers in the rear as well, i'm just wondering if 5mm will be enough (I'm sticking with the stock tire size, on stock sport wheels).
It should be perfect for you with the beefier tire. Take some pics and post 'em up after your install!
Old 02-12-2012 | 02:20 PM
You guys should be adding spacers to the front. wider stance in front is better for handling. wider in rear could mess with your handling in a negative way
Old 02-12-2012 | 04:09 PM
Goobers's Avatar
From the sounds of it, I don't think they're doing this for the handling...
Old 02-13-2012 | 01:55 AM
Not in the slightest! Although, I highly doubt adding a 5mm spacer is going to effect the handling that badly... I just want to lose the ridiculous sunken wheel look in the rear, so it matches the fronts
My Fit is to get me to work and back. Thankfully I have a turbo Teg for all my serious fun, and weekend shenanigans
Henry Cruz
03-09-2019 09:49 AM
liverpoolfcfan
08-24-2013 07:28 PM
melv0
05-20-2012 12:56 PM
schuey1010
09-30-2011 09:25 PM
heymikesays
10-25-2006 10:50 AM
