Little photo shoot at different angles!
Stay "ignorant" because it seems you actually like to drive your car and not be a sh-low bitch like the many that exist online no matter the car.
What you could look at picking up to help with the rubbing is a stiffer stabilizer bar to try and deflect some of the leaning. The SWIFTS I don't believe lower that much up front, they usually only drop like 20~25mm at most on every application that I have ever seen and the spring rates are slightly stiffer than stock to also help deter some of the sloppy sway of the vehicle when making turns.
Just checked Tohatsu's site and they list the GE8 as having 20~25mm drop front and rear for their SportMach's.
I will be turning the car hard in 9 days down on the Dragon
