Metra 40-HD10 Antenna Adapter Question
I recently installed an aftermarket HU on my 2009 Fit Sport. It is having a lot of static when I am listening to FM radio. I wonder I hooked it up correctly or not. On the Metra 40-HD10 antenna harness, besides the regular antenna cable, there is another wire. I connected it to the HU wire labelled "antenna power supply". Did I do it correctly?
^ What he said. As long as the new radio isn't junk, there shouldn't be a noticable increase in static- if anything, with a decent aftermarket unit, there should be less!
Whenever you do a relatively simple swap/"upgrade" of any kind, and something stops working the way it should, always check your work. I keep a plaque saying something like that in my shop- 9/10 times, it's correct Mark W.
where is the blue lead? do you mean the remote blue for like amps?
Your Pioneer (based off your other thread) harness should have a blue wire and a blue/white wire. The blue wire is the power antenna lead (which is what your blue wire on the antenna adaptor connects to) and the blue/white is amp turn on.
WeaponR23
07-28-2011 05:06 PM
