GE8 Amp/sub combo - raised hatch floor
Wonder if this person is a FitFreak.net member?? Pretty cool amp/sub install here!
http://www.cardomain.com/ride/3327336
Here is their complete mod list:
- Custom Exhaust
- Window Tint
- (((xm)))
- Aftermarket Navi
- Focal Component 6 1/2 Fr Doors w/ Focal tweeters in dash
- Focal 6 1/2 R Doors (sorry speakers in doors, no pics)
- 2 Fosgate Power Series Amps
- Custom Floor mount Sub & Amp Box
- Pioneer Premier 10" Inverted Sub
- Custom Exhaust
- Window Tint
- (((xm)))
- Aftermarket Navi
There isn't one... call AAA or stash a can of Fix-A-Flat somewhere. Personally I'm a "roll the dice" type of guy and just threw a can of Fix-A-Flat back there and called it good. I'll need all new tires soon anyways...
I ended up building a similar setup with a friend (as shown below), but for now my amps will need to stay above the false floor as they got a bit too hot. I have a few options but for now I am thoroughly enjoying the extra bummmpp!
https://www.fitfreak.net/forums/fit-...t-set-way.html
Below was my setup in my Integra.
I was running a Kappa 255a 5 Channel Amp with 2 10" kappa free-air subs. the subs were just forward of the amp/door. what you see above the door is the hatch cover (just kind of hooked over the top to keep up the sub door. This Setup raised my trunk floor about 4" and the sub magnets sat next to the spare tire (slightly forward and off to one side - about 1/2" from the spare tire tread). Didn't have to remove the spare which was nice... The factory carpet laid flat to the back of the car so you had no idea there was a system back there, even with the hatch open. There was about a 2" drop at the front of the rasied floor (right behind the back seats) but it didn't affect anything because the back seats never layed flat, about a 15 degree angle sloping towards the back of the car) Still have everything from the car - will probably sell and just put a basslink in the back. I really don't have time to do this level of work again... Plus my priorities with a 3 yr old have changed a little.
~SB
~SB
Bennet Pullen
11-20-2007 10:15 PM
