Vibration in hatch panel
Old 11-19-2015 | 01:08 AM
rc251's Avatar
Hi, I have a 2013 Fit Base, and it's developed an annoying vibration in the hatch area, especially when driving at higher speeds. I've seen previous topics about vibration with varying causes, so in order to narrow it down, I had someone sit in the back and try to find the sound. When my friend lightly pressed on the plastic hatch panel on the driver side, the sound stopped, so it's definitely coming from the panel or something underneath.
Has anyone experienced something similar or have any tips on how to reduce the sound? Is it worth removing the panel and seeing if something is loose underneath? Is the panel easy to remove? Thanks!
Old 12-14-2015 | 03:36 PM
FantasmoDelFuego's Avatar
I actually had the same problem in my 2011 fit sport. I stuffed a bit of cardboard (thick enough to fit fairly tight) between the window and hatch panel and that stopped the vibration.
FunkTastic
10-28-2020 08:31 AM
Connor MacInnis
05-25-2019 09:49 PM
VT-Fit
11-25-2017 01:20 PM
Marsha61Fit
06-18-2008 04:27 PM
smatts
01-09-2008 10:07 PM
Quick Reply: Vibration in hatch panel
