Passenger power mirror not working
My passenger side power mirror is not working, yet my driver's side works just fine. I think that would rule out a bad fuse; is it likely a wiring issue?
I haven't been able to find a guide on the wiring for the power mirrors but I'd like to get an idea of what I will need/what could be wrong before I start taking things apart. Any suggestions?
Could be wiring... Could also be a dead motor. Did you check to see if there is/isn't a separate fuse for left/right side mirrors?
The mirrors should have a quick connect plug right at the door (or the mirror housing itself), so once you open it up, you can unplug it.
On the other hand, if you're like some other unlucky folks and had a squirrel or something chew through you wires somewhere... Ouch. The rest of the wiring is a fairly long harness for a lot of stuff.
Two wires from each mirror run to the switch on the door so unlikely it is a fuse. Most likely a bad actuator in the mirror.
Give me you Email addy and I can send you that section of the manual to test and replace.
bill
bill
Aussie
07-11-2019 11:03 AM
gmbdelsol
07-12-2010 06:59 AM
