Braking issues
Braking issues
Hi all,
My GE8 is about 217,000kms (~134,000 miles) and has been a very reliable car so far. However, it started to develop an issue when braking. At the beginning, it was happening randomly, but now it seems to be more present. There are 2 issues that might be related. I'm no mechanic, so I wanted to ask around for what you guys think could cause this.
I believe this might be the same issue. Over the past months I've done a couple of things that did not fix the issue :
Nothing fixed the issue. As I said, at the beginning it was happening randomly but now it is getting more frequent. On my GE8, I never changed anything about suspension, tie-rods, wheel bearings, etc. Could one of these components failing after that much miles ? I wouldn't be surprised honestly. I live in Quebec and roads are mediocre at best.
As I said, I am no mechanic, but I am more than happy to jack the car and investigate few things such as checking if a bearing is bad...I just need to know how to do it
Thanks for any comments and suggestions guys
Neo.
- Clunking noise when braking lightly at slow speed. Please look at
- When braking at high speed (exiting an highway), the brakes are uneven. There are no noises, but it feels like the vibrations of that clunking noise above. I can feel it in the steering wheel and brake pedal. The steering wheel however is very responding and I have no issues controlling it.
- Changed my winter tires for summer tires (including the wheels themselves)
- Did an entire brake cleanup at the garage. The mechanic said that I still have enough pads left)
- Did an alignment
Neo.
I'd start by replacing the rotors. They are cheap and likely the culprit. My guess is they are slightly warped.
Centric Premiums are $22.79 ea at Rock Auto. High Carbon's are $25.79 ea. Around $20 gets you a new set of pads.
If your brakes have some miles on them, ~$70 puts new rotors and pads on the front. Money well spent in my opinion.
Those are US$ prices, but it's fairly cheap regardless of country.
Not trying to hijack the thread, but I'm due for front pads and can't seem to find a RECENT post on what a good low-dust replacement would be. I'm in TX, and it's gettin' hot. If a good deal on rotors came along, I'd blindly do them too, but I'd wager whatever's on there now is fine. [Sqeeking ATM, not grinding.]
Are those Rock Auto Centric's the deal of choice around here? That said, who's got some current market pad recommendations?
Are the NAPA ones any good ? My GE8 is my daily driver so I don't need any Brembo stuff on it. Basic and reliable ones should do and in my experience, NAPA isn't too bad. Do you have any experiences with NAPA pads and rotors ?
Thanks !
fr8train
07-24-2019 06:37 AM
justinb001
09-11-2018 06:06 PM
Blackberry Goose
09-08-2016 10:23 PM
