Engine Flood
Old 10-19-2016 | 03:23 AM
phenoyz's Avatar
Engine Flood
Hello
My cars engine stalls/dies out when coming to stop/traffic light.
***Its like the engine is being flooded with gasoline*** ???
I already replaced the all 4 coil-packs all are OEM (NEW), spark plug all NEW.
I went to the dealer and had them adjust the valve for $300.
Bought a new Battery. Always replace the engine air filter after 3k miles.
Engine is stock.
I always clean the MAF sensors, terminals.
On one occasion this happened the "check engine light" came out, after
a day it disappeared. and everything was OK, this happened three or four weeks ago.
(This stalling/engine dying-out started to happen last year.)
thanks
Old 10-19-2016 | 11:04 AM
arrow_runner's Avatar
POSSIBLY a bad cam/crank sensor?
Old 10-19-2016 | 11:56 AM
phenoyz's Avatar
If this is the problem will this be an expensive fix?
"Also this time the check engine light DID not came out."
If I came to a stop light the engine dies-out , whats dangerous is
even when I am on the highway the engine just dies....
Old 10-19-2016 | 12:29 PM
I don't think so. Looks like the part is only about $40 and not terribly inaccessible. It could easily be something else but I wouldn't be surprised if it was that sensor.
You should take the car to autozone or something and ask them to scan it for codes even though it may not have a CEL light on.
Old 10-19-2016 | 06:56 PM
phenoyz's Avatar
Today engine is working perfect. But i really need to find out
What part to replace.
Where can i find that cam/crank sensor i will just replace it.
Thanks
Old 10-20-2016 | 11:03 AM
I looked at the engine diagrams and on the GD3 it's down by the crankshaft pulley but I can't find one on the GE8. I'd have to assume that the GE8 has a cam or a crank position sensor but I can't find it. Call up a honda dealership and ask them.
I'd also look into that faulty ignition switch theory in the other thread. I've never had that problem in a car so it didn't come to mind.
Old 10-20-2016 | 05:54 PM
phenoyz's Avatar
....thanks....
Old 11-11-2016 | 02:34 AM
phenoyz's Avatar
it was my fault, it seems when I cleaned the maf sensor I did not put it back tight enough....
now everythings OK
phenoyz
04-14-2015 11:16 AM
bjvalencia
01-30-2012 10:26 PM
hydrogennine
09-08-2011 12:59 AM
yogs
08-06-2007 10:29 PM
Velikimrav
Canada Fit Forums & Clubs
04-12-2007 01:57 PM
Quick Reply: Engine Flood
