Ignition switch will not turn
Old 12-08-2015 | 05:27 PM
Fitgirl99's Avatar
I have a 2009 manual transmission. . Yesterday the key had some resistance going into the ignition switch and when inserted fully would not turn. I sprayed with WD-40 and Graphite. This made the key easier to insert but still did not allow for the switch to turn. I turned the steering wheel between the two stops and tried for 2 hours to get it to turn. I tried my usual key and my unused spare, with the same results. I finally got it to turn once and drove it to my mechanic. He called this morning and said I would have to take it to a dealer. The ignition switch is defective. He got it to turn once but that was it. Might be $$$.
I did a search and saw a few people with this problem but not many. How common is a defective ignition switch for 09s, and do I have any leverage with the dealer. Warranty is expired.
Thanks for your feedback
Old 12-09-2015 | 04:50 PM
Macswfc's Avatar
Had a similar issue, had to get the ignition cylinder fixed (dealer called in a locksmith) and I got a new key made as the old one was worn and probably caused the issue in the first place.
Old 12-10-2015 | 09:55 PM
geopat's Avatar
Had something similar happen to my gd last year. The dealer wanted around $500 for a replacement switch assembly. They wouldn't sell just the tumbler and column lock which is all I needed. Ended up buying a column from a wreaker for $100 swapped in my tumblers so I retained my stock key and bolted all of my electronics to the new part.
Old 12-11-2015 | 05:10 PM
Txfitish's Avatar
Has happen to me before anyone have any clues?
Fweemn
05-17-2023 11:43 PM
soccerdude
09-17-2014 11:56 PM
gcisko
05-13-2011 07:13 PM
CuTeBoi
07-10-2007 08:08 PM
Anastasio
07-04-2005 12:20 AM
