Manual transmission first gear question
Old 06-02-2015 | 01:29 PM
Jeema's Avatar
Hi guys,
Just got a 2012 Fit and I have a question about the manual transmission. I noticed that shifting into first gear at a stop sometimes seems a little bit notchy unless I leave the clutch in for a second or two. I assume this is due to the first gear synchro matching up the rotations?
Anyway I've read that first gear synchros are usually weaker, so I guess I'm just wondering if I'm being paranoid and this is relatively normal or if I should take it into the dealer (the car has 44k miles and is still under drivetrain warranty btw). I seem to remember that my old 98 Integra was kind of like this too, so maybe it's just a Honda thing...
Thanks
Edit: I should clarify that this is where the car is in neutral at a light and then I put the clutch in and shift into first when the light turns green, in case that wasn't clear...
Old 06-02-2015 | 01:55 PM
Fit Charlie's Avatar
Try pulling the shifter back into second and moving to first from there. I picked that habit up years ago and don't even notice if it smooths things out on the Fit.
Old 06-22-2015 | 06:27 PM
gkitf16's Avatar
Good point. All you're trying to do is bring the spinning clutch and trans to a stop before engaging 1st. It takes less effort to drop it into 2nd, then slide up to 1st. Otherwise, give it several seconds to coast down after depressing the clutch. These transmissions have such lightweight parts, shouldn't take very long.
Anthony Villeneuve
04-23-2019 11:07 PM
Eric Satoshi Harima
04-13-2019 03:28 PM
Jeema
03-25-2016 07:46 AM
Fizz
11-12-2014 12:39 AM
phuccer
01-30-2011 07:19 PM
Quick Reply: Manual transmission first gear question
