Where Is Clutch Master Cylinder?
Where is the clutch master cylinder? I cannot see much of the rear of the engine bay. I gather a lot of things have to come off before I can get close to the clutch master cylinder.
Thanks.
Thanks.
Below the brake booster on the firewall? Got it.
No issue (yet). I'm just trying to think through why my clutch engagement and shifts are so sloppy. It's probably pilot error. But, even so, I wanted to have a look at the clutch reservoir and master cylinder.
Not likely driver error. Knowing the clutch is sloppy means you know what a normal clutch pedal should feel like. I was on the track with my Fit and I thought the same.
The clutch master on the GE8 Fit has a "Delay Valve" built onto the clutch master. You can replace it with a clutch master for a 2004 Civic EX 1.7L ($36 at Napa). It's a direct bolt on.
NAPA Part number 72410
Turns out; that was all it was. Check out my page for pics:
https://www.fitfreak.net/forums/2nd-...ml#post1244618
Thanks, De36. I forgot about the clutch delay valve. It seems quite a bit worse than on my 08' Fit and my '07 s2k.
Just so that I have this straight: The battery and the air box have to come out. Then, the rest is just swapping out the OEM CMC for the '04 Civic CMC (not just any '04 Civic, bit the 2004 Civic EX 1.7L???). Is that about it?
Check with the GD guys I believe the GD FIT has one too. The S2K may or may not have one, that's out of my spec of knowledge.
Use that NAPA number and buy DOT 3 and that's it. Simple. Direct bolt on. I have a CAI; so my install is different. Use a mirror to get a visual, you will work blind.
Are you saying that you buy the NAPA equivalent of the 2004 Civic EX 1.7L clutch master cylinder rather than the 2004 Civic EX 1.7L Honda OEM part? I've got no problem buying the Honda part. This isn't something that I need to save money on.
Thanks.
I've been dealing with the CDV okay but it could be better. I shouldn't be happy but I kind of am.
I have a very early (October 2007) JDM GE8, and I can categorically say there is no CDV in mine. Whether or not it's the origin, or the age of the car, or it's been changed out at some point before I owned it, I don't know. But I have to be much more careful when I downchange at high speed or on inclines than in other, more powerful, cars without CDVs. I'm absolutely having to do the slipping myself.
Light flywheel, light car, small engine, possibly even crappy engine mounts can make for a rough ride if you're not really careful on the clutch when you want to slam it. Maybe it's just mine. Maybe everything's broken.
I have a very early (October 2007) JDM GE8, and I can categorically say there is no CDV in mine.... I'm absolutely having to do the slipping myself.
Light flywheel, light car, small engine, possibly even crappy engine mounts ... Maybe it's just mine. Maybe everything's broken.
Haha. Yeah you shouldn't have to slip the clutch, it sounds like you have another issue.
here is a pic with the delay clutch valve (the "triangle" valve):
I may wait until my warranty expires, too. This car has not inspired a lot of confidence, which is disappointing in a Honda. I hope they get rid of the current CEO and go back to making cars the way they used to.
@De36: The CDV on the s2k was not a triangle shape. As I recall, it was an oblong, cigar shape affixed to the transmission case, and it had a bleeder valve. But thanks for making this clear.
Okay. Back to Fits.
Slipping the clutch is part of good clutch control. If you drop the clutch every time then you're going to destroy your clutch and your mounts. The CDV slips the clutch for you when it delays the plates coming together. That longer period of slight contact it causes reduces drivetrain shock by slipping the plates together.
I don't think it came with it. The car was completely stock when I bought it, so I can't imagine that the only thing they did was swap out the master cylinder.
"That longer period of slight contact" — That's the problem, isn't it? Clutch plate wear. Not to mention poor response due to the slipping. The CDV was never meant as an improvement to anything. I believe it was designed to deal with idiots who dump the clutch because they think it's "cool," then go crying to Honda to cover a new clutch under warranty.
