Oil Change Level or Tilt
Old 03-14-2015 | 11:11 AM
Bowbridge's Avatar
I have a 2010 Sport and always do my own oil change. I've wondered if it's better to change the oil on a level surface or a tilted one? Would I get more oil out if I tilted the car towards the drain plug? What do you folks do?
Old 03-14-2015 | 04:55 PM
DrewE's Avatar
I don't think it makes a huge difference. I've done both, probably tending more towards the tilt—but not for reasons of drainage as much as because driving the front wheels up my ramps gives easier access and better clearance for my drain pan (which is a bit on the tall side).
Old 03-14-2015 | 07:14 PM
c3kay's Avatar
I don't think it makes a difference. Oil pans drain toward the drain plug when flat. That's just the way they're designed.
Old 03-15-2015 | 10:02 PM
Uncle Gary's Avatar
I can't "fit" under the car to change the oil unless I put the front of the car up on ramps, so mine's always been tilted a bit toward the rear. I don't think it makes much, if any, difference.
Old 03-16-2015 | 10:12 AM
Gordon Smith's Avatar
Although I can't picture the configuration in my mine, just now, (I'm old and sometimes confused), I DO KNOW that whenever I shimmy under the car, after getting the front end up a foot or so, that I ALWAYS think to myself, "WOW, how fortunate, the drain plug is situated now, to get every last drop out…better than if the car were flat!"
The rub, is than my FIT is a 2012 base model, and I don't know if your model is identical in this regard.
cleanest135i
05-16-2017 08:05 PM
MrKeishii
04-09-2014 12:56 AM
timemachine
05-14-2012 02:09 PM
Nice Fit
01-16-2012 08:59 PM
vwli
07-08-2009 08:07 PM
